6.1 - error message
I'm happy you found it and are back in business!
Something simple like that sure can mess things up.
Happy printing!
Julie
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Wednesday, March 28, 2012 8:00 AM
Subject: RE: [Vantage] 6.1 - error message
Julie ~
Thanks again for ALL of your suggestions!! :)
We finally found it. Someone had done a new client install and it was pulling the working directory from the wrong place. That messed up everyone else.
We now have it fixed and are happily ready to print a couple of days of invoicing.
Thanks again!!!!
Tricia Simon, Controller
Riten Industries, Inc.
800-338-0027
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Julie Lehmann
Sent: Wednesday, March 28, 2012 8:40 AM
Subject: Re: [Vantage] 6.1 - error message
Tricia ~
Is this just happening with invoices? Could it be you have one that is bad?
Maybe delete it and pull it back in to re-invoice?
I remember getting an printing error similiar to that, when we didn't have an available
license, but I'm not sure if it was #534.
It's not an ODBC connection is it?
Good luck!
Julie
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com>'
Sent: Wednesday, March 28, 2012 7:23 AM
Julie ~
Thanks! Our problem is that we can't even print preview! :(
Any other thoughts???
Thanks again!
800-338-0027
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Julie Lehmann
Sent: Wednesday, March 28, 2012 7:59 AM
Tricia,
I went back and found an old message regarding this from someone on the list along time ago:
If it is a modified crystal report, the error is caused by crystals
ability to locate the correct dbf location.
Have the person who modified the report, open it in print preview mode,
don't print it, and then exit out of Vantage. This creates an xml record
in your temp/working directory.
Now open crystal and open the corresponding crystal report file and
select Database \ Set data source location from the menu.
Browse to your Vantage working directory and select the xml file that
was created by the print preview.
After the connection has been updated, select Database \ Verify Database
from the menu.
You should receive a popup message "Database is up to date"
Save your changes and exit.
HTH,
Julie
Mercury Minnesota Inc.
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Sent: Tuesday, March 27, 2012 7:37 PM
Subject: [Vantage] 6.1 - error message
Folks,
We are on 6.1. Suddenly getting an Error 534 when trying to print an A/R invoice. There have been no changes to either the form or and update as far as we know. Can anyone provide any direction of where to look or what to do so we can print invoices again??
TIA!!
Folks,
TIA!!
Can't quite remember the error codes for 6.1 but a good place to start will be if there is a large comment on either the header or line. Make sure the dbf files that 6.1 produces are in the same place the report expected them (sometimes if someone install a new client and the location specified was different to normal then it could affect all). A longer shot is if there's a problem with the local printer driver (if it's only one person affected) - if their default paper size is set to something small and it was intended to come out on Letter or A4 then it will error. Those were the most common ones I used to come across.
Hope that gives you something to look at.
Martin Horton
Business Systems Manager
direct line: +44(0)1889 272250 mobile: +44 (0)7875 404841
Skype: marthorton Skype number: +44 (0) 121 288 3133
[cid:image001.jpg@01CD0CC4.F61B9AE0]
Broadcrown Ltd. Airfield Industrial Estate, Hixon, Stafford, Staffs ST18 0PF, England
tel: +44(0)1889 272200 fax: +44(0)1889 272220 www.broadcrown.com<http://www.broadcrown.com/>
----- This email and the information it contains is confidential and may be legally privileged. It may be read, copied and used only by the intended recipient. Internet communications cannot be guaranteed to be secure or indeed error free as information can be intercepted, corrupted, lost, destroyed, delayed and or contain viruses. Broadcrown Ltd has scanned the email for viruses but does not accept responsibility once the email has been transmitted. The receiving company should scan the email and attachments (if any) for viruses. Any views or opinions expressed within this email are not necessarily the views or opinions of Broadcrown Limited except where the sender specifically states that they are. If you have received this document in error please email the sender and delete the message from your computer without taking copies -----
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tricia Simon
Sent: Wednesday, March 28, 2012 1:38 AM
Folks,
TIA!!
Tricia,
from the menu.
HTH,
Julie
Folks,
TIA!!
Julie ~
Thanks again!
800-338-0027
Tricia,
from the menu.
HTH,
Julie
Folks,
TIA!!
Tricia ~
Good luck!
Julie
Julie ~
Thanks again!
800-338-0027
Tricia,
from the menu.
HTH,
Julie
Folks,
TIA!!
Julie ~
Thanks again!!!!
800-338-0027
Tricia ~
Good luck!
Julie
Julie ~
Thanks again!
800-338-0027
Tricia,
from the menu.
HTH,
Julie
Folks,
TIA!!
