That depends how your users are logging onto the server. With Citrix sessions and prg91.d, I could see who's process was using assigned to the process using a tool called procexp.exe (process explorer). It's a free utility available from sysinternals.com
Pete
Russ Dover <rustover@...> wrote: Todd
If someone is opening a report three times they have three separate connections
to the data base in Promon. I don't know of a way to see what user is sucking
up processor time. If you check users in Vantage against users in Promon the
difference is either Report Builder users or ODBC users. I don't know how to
see this with PET. I also don't know of a way to limit the number of
connections a users can make.
Russ Dover
rustover@...
717 336 2340 voice
717 336 7507 Days at work
717 336 4182 Fax at work
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
Pete
Russ Dover
> I have a situation right now that occurs from time to time. CPU on Vantage server is pegged at 100% and it appears to be 3 specific occurances of _mprosrv that are using it all. In the past I have seen where if a user runs a report and gets impatient and runs it again because nothing seemed to happen (and then again and again and again....assuiring that nothing will happen) we end up with a bunch of run away processes and the whole server comes to its knees.Russ Dover
> So, is there any way to identify which User #s in ProMon or PET or something are responsible for the CPU usage? Normally we run 10-15% CPU utilization on the server.
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
rustover@...
717 336 2340 voice
