Yep... a complete Dump and Load of the database. When the system starts
to gradually get slower and slower then I perform a Dump and Load.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of liss_c
Sent: Tuesday, October 05, 2010 12:00 PM
Subject: [Vantage] Re: 8.03.408B Printing Issues
Thanks Blake,
You mean a "dump and load" of all the system reports?
"Blake Clemens" <blake.clemens@...> wrote:
Behalf
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of liss_c
Thanks Blake,
>which
> Not really, it kind of just went away. We performed a Dump & Load
> seemed to make these errors/problems happen less frequently. We also10
> discovered that most of our Crystal Reports were written with Crystal
> but Vantage 8.03.400 and beyond uses Crystal 11 for their reports.Once
> we opened all of our reports in Crystal 11 and resaved them printing[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> seemed to work a lot better. Not sure if any of this fixed the problem
> but it doesn't seem to be happening anymore. As crazy as that may
> sound....
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of liss_c<mailto:vantage%40yahoogroups.com> ,
> Sent: Monday, October 04, 2010 8:35 PM
> Blake,
> i am having the same issues but on Epicor9. Did you come up with a
> resolution for this?
> Thanks
> "Blake Clemens" <blake.clemens@> wrote:makes
> > Since upgrading to version 408B we've had some unusual behavior
> printing
> > in Vantage. Mainly Pack Slips but Invoices and Purchase Orders are
> > affected as well. The first problem is that the two users who print
> > Pack Slips will occasionally receive errors while printing which
> > them exit our of Vantage. The error numbers are (7224) (7249)(7209).
> > Vantage says that the errors numbers reflect connectivity issues butprinting
> > I've installed a sniffer and everything looks fine. The other
> > issue that we experience is that when submitting Pack Slips to printwe'll
> it
> > will take an extremely long time to get them to print out. Then
> > wait 5-10 minutes in between each Pack Slip. This never happenedup
> before
> > upgrading to 408B. I noticed that if you look at the system monitor
> the
> > print request is in the History tab as "Complete" but doesn't show
> inknow
> > Reports or Active tabs. Has anyone else had an issue like this or
> > what might be causing these problems??[Non-text portions of this message have been removed]
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
