A little late on your question but we had this happen a couple years back and found a corrupt sql db. you can run checkdb, we found that the peglink table was corrupted and were able to fix by rebuilding the table from a good backup.
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> We have not been able to get a successful MRP run, same unfirm jobs keep hanging up until we have to cancel. Occasionally, it will get past the unfirm jobs but hang up on the same part number
> MRP logs, server logs, have all been sent to support with no resolution. We have relatively few jobs (both firm and unfirm at anytime, about 1000 active parts. Have run MRP with finite, infinite, multiple servers, full regen, net change, recycled MRP jobs, etc.
> First time in years I have encountered this without able to find a root cause
> Anyone else out there running into MRP hanging up each time?
