Marilyn,
Thank you for the information. I am going to pass along the information.
Basically since we are not using MRP, would we be safe to uncheck the
Process MRP checkbox and this won't happen again? That's a solution that I
can handle for today.
Thank you,
Lori
Lori A. Baker
Accountant/Information Systems
CardioPak Inc.
406.259.6387
Fax: 406.256.9875
lori_baker@...
www.cardiopak.com
mfairchild@...]
Sent: Wednesday, January 16, 2002 2:12 PM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] System generated unfirm jobs w/o the MRP module.
5 .00.335
Lori,
I just spoke with support about this issue. I was told it is a known bug
that they had been trying to recreate, and have just managed to do so. I
was told to go into the jobs that are unfirm, mark them firm, engineer them
and delete them. Then go into the part master and uncheck the Process MRP
box. Supposedly this should keep it from happening again. I didn't realize
this until after I had talked to support, but it would appear to be
happening to only stock items. Not sure about tht yet, but first looks seem
to indicate this.
Marilyn Fairchild
Systems Administrator
Pickwick Manufacturing
lori_baker@...]
Sent: Wednesday, January 16, 2002 2:36 PM
To: '
5 .00.335
Has anyone contacted support regarding this issue? We are running 5.0.335
and it has just started happening to us. If this has not been discussed with
Epicor I will be calling today as it's causing problems with allocations as
well PO suggestions.
Thanks - Lori
Lori A. Baker
CardioPak Inc.
406.259.6387
Fax: 406.256.9875
lori_baker@...
www.cardiopak.com
RobM@...]
Sent: Tuesday, January 15, 2002 1:21 PM
To:
Subject: [Vantage] System generated unfirm jobs w/o the MRP module.
5.00.335
We do NOT have MRP module but recently, open jobs have been showing
up for one part number. The jobs appear to be system generated as
they are marked unfirm. We have compared all settings for the part to
other parts in the system and can find no differences. The Process
MRP IS checked on the part, but it is checked for other parts as well.
What would tell Vantage to generate jobs for this one part but not
the others?
Why would an unfirm job be created as opposed to just generating a
manufacturing suggestion?
* Rob McFarlin, Controller
* Accel Group, Inc.
325 Quadral Dr.
Wadsworth, OH 44281
* (330)336-0317 x114
* FAX(330)336-1224
RobM@...
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
