Thank you Julie and Tony.
--- On Wed, 4/8/09, Tony Hughes <thughes281@...> wrote:
Subject: Re: [Vantage] ABC Cycle Counting; 407A
Date: Wednesday, April 8, 2009, 1:28 PM
Jonathan,
It will go down the part list. It won't repeat an 'A' part until you've counted all the parts at least once.
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Wednesday, April 8, 2009 12:27:57 PM
Julie,
Does the ABC Count choose part by random or does it go right down the part list?
Jonathan Lang
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Date: Wednesday, April 8, 2009, 10:10 AM
Jonathan:
I don't know about 407A, but at least in 6.1, the problem with the parts showing up again for the next cycle count is that we didn't count every single warehouse location that the part existed in. Check your "Count Date" in your warehouse screen for each warehouse to make sure they've all been updated. I added that field to our part tracker warehouse screen so it is easy for our cycle counter/inventory people to check. Again, we're on 6.1 so this could be different for you.
Hope that helps!
Julie
Mercury Minnesota Inc.
----- Original Message -----
Sent: Wednesday, April 08, 2009 8:14 AM
Subject: [Vantage] ABC Cycle Counting; 407A
Good Morning all,
I have an issue with Count Entry and Blank Tags.
ABC Code Maintenance has the information for each A, B, C, and D, no problem there. When we go to Count Entry, Count Groups, put in the Limit Number of Selected Parts say 100 we have 2 problems.
1. We get blank tags. All the have is the Tag Num
2. When we do a count one day and post then do a new count the second day we get the same Selected Parts as we did the day before. For example:
Monday I create a group called "Why Me". I selected the Limit Number of Selected Parts and entered 10. Printed the Tags( Which are blank, but for the sake of argument) and waited for the actual count. Finally i get to Post.
Tuesday I create another group called "Here I Go Again". I selected Limit Number of Selected Parts and entered 10. I get the same 10 parts as I had on Monday.
My Minimum Volume is set as Follows: 99,999.99, 5,000.00, 1,000.00, 500.00, .01
Count Frequency is set as follows:10, 30, 60, 75 and 190.
Any Ideas?
Jonathan Lang
jlang@oilrite. com
Fax: (920) 682-7699
