Kristine Fierce
Kristine Fierce
Xml generates. Vague error in report tab(provides no detail) nothing in the server log, nothing in event viewer, history shows complete no error, never pops up. I have the custom report folder in \\Server\EpicorData\CustomReports
thanks
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
Visit our newly redesigned Website at www.dsmfg.com
Sent from my iPhone
On 5 Mar 2016, at 7:23 AM, Rob Bucek rbucek@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1191740978ygrp-text"> <p>
thanks
Rob Bucek
D&S Manufacturing
</div>
Rob,
The files should be in \\<Server>\EpicorData\CustomReports\<file name.rpt>
Are you getting the Crystal window to popup? You can also try opening the System Monitor, highlight the report line, then click on Actions > Download Report Data. That might give you more information. If it can't find the file, it will tell you that. Then you know that you are not pointing to the right place the file is stored. Other than that, I would say to check your RDD.
Hope this helps!
Bethany Rye
Epicor Business Analyst
PTI Engineered Plastics
You need to move your reports to C:\EpicorData\CustomReports
Rob Bucek
D&S Manufacturing
301 E. Main St.
Sent: Friday, July 8, 2016 4:50 PM
Subject: [Vantage] Re: any tricks to getting crystal rpts to display for 10.1.400?
Has anyone had any luck with this? I setup my test server to 10.0.700.4 and it was working perfectly fine with crystal, upgraded to 10.1.400 and this no longer works. Loaded the xml to the crystal report to update the tables and it keeps saying COMPLETE but does not generate the report. XML is loaded with the correct data. I tried moving the location around and changing the report style path with no luck.
If you move them to the location Rob indicated, then the path stays the same as it was by default in 9. If you put the custom reports somewhere other than the default location in 9 then Robs suggestion would not work.
Joshua Giese
Technology Solutions : CXO
Direct Phone:
920.593.8299
Office Phone:
920.437.6400 x342
Sent: Monday, July 11, 2016 9:50
I've tried that. Maybe I've got the wrong path on the report style? What is your path for the file in the report style for your reports?
