Crystal in E10 Blank Title 136031
- Epicor recommends that the Crystal Reports be stored in the c:\inetpub folder.  We put ours in a Custom Reports folder and from E9 to E10 this is how we were directed to store them.
Source=Epicor 9.05 (e.g. E:\Epicor905\server\reports\CustomReports\*.*)
Destination=Epicor 10 (e.g. C:\inetpub\wwwroot\ERP1007002\Server\reports\CustomReports\*.*)
- If you contact support they will tell you that don't support it and they recommend uplifting all of your reports to E10 but they do have a pretty good document they'll send you that puts together a bunch of answerbooks on Crystal Reports and E10.
Crystal in E10
While I know it is not technically supported, or at least won’t be long term; Are there any instructions anywhere on EpicWeb or that anyone has on how to use crystal reports in Epicor 10? Where they need to go? Which runtime works?
I know they are all going away, but in the short term, I need to do some testing on the upgrade and would like to get existing custom reports updated for the testing process while learning SSRS to eventually convert them all down the line.
If you can, call tech support.  They actually do have something you may be able to use, although I am not sure if it will answer ALL of your questions.
Manasa
Sent: Tuesday, April 14, 2015 10:23 AM
Subject: [Vantage] Crystal in E10
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
Technically it is supported in E10. I have been on E10 for 13 months. We rely heavily on crystal…We pay maintenance on crystal so they will support it…
Sent: Tuesday, April 14, 2015 10:27 AM
Subject: RE: [Vantage] Crystal in E10
Manasa
I was able to pull the information off of EpicWeb, looks pretty thorough.  I'm not going to be doing the development so I don't know how far our developer got with them.  Just do a search in Tips for "crystal reports".  There is also a zip file you can download with crystal reports versions of the reports for E10.
Do you happen to know where the zip is located? I am not seeing it in the download section anywhere.
Also, in one of the tips, it mentions
“(attached)
CrystalReportStyles.zip
a SQL script to populate the Report Styles table with the Crystal report records. The Report Style records will be removed on every upgrade to a newer version so keep the script handy until all reports have been migrated or create a custom Report Style for the Crystal reports you wish to use for an extended period - custom Report Styles will not be removed during an upgrade.”
But I don’t see anywhere to get that .zip file or do I need to call support to try to get it?
Sent: Tuesday, April 14, 2015 11:00 AM
Subject: [Vantage] Re: Crystal in E10
The reports are on the Downloads page, last file under 10.0 (for version 702a, which is what I'm converting from).  This zip is just the report though.
I don't have the script to auto-populate the styles.  We thought we'd have to pull in the report data definition and setup a new report style (package it all as a solution for future reference).  I'll have to check into that script you mentioned.
