Anyone running Crystal Reports 2008 SP4 Runtimes?
I originally tried to just use a square label, and I thought it worked, but we print some labels that have varying lines, and if the label ran long, I'd lose data between the 2 and 4 inches. It wouldn't just wrap to the next label. Weird, weird, stuff.
--- In vantage@yahoogroups.com, "eackerson1" <eackerson@...> wrote:
> The only way we could make labels work with the Crystal SP3 Runtime was to make them square or alter them to be portrait mode. Anything that was landscape would shrink and rotate upon printing. The crazy part was, everything looked ok in developer and preview mode. It was only when you printed they would blow up.
> We wound up taking all of our labels (15 different styles) and basically just tricking the printer. Specifically we would take a 4 x 2 label but tell Crystal the paper size was 4 x 4. It sounds ridiculous (and it is) however this did work for us as a workaround.
> Glad to hear SP4 helps this issue.
> Eric
> --- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@> wrote:
> > Jenn,
> > I tried any number of combinations of disassociating paper sizes, changing paper sizes, even using the seagull drivers but nothing worked properly until I moved to CR2008 SP4.
> > We use a 2.25" wide by 1.25" tall label, and defining that size in the designer defaults it to portrait and you can't change it.
> > At one point I tried defining a 2.25" square label, but if the label data required more than one label, i'd lose data between labels. That was strange. Other times It would resize the label and print a small square label in the middle of the rectangular label. Weird stuff.
> > I'll be testing things a little more and will let you know if I run into any other issues.
> > --- In vantage@yahoogroups.com, "Jennifer" <Jennifer.Lisser@> wrote:
> > > Jason,
> > > We are testing the upgrade to 9.05 and will be using CR2008, have a lot of labels that are critical. I'm curious if you dissassociated formatting page/printer paper size and still had problems with them. I was hoping to go seagull drivers (that is the way to go from what I hear) and set the margins/size manually in the report to make it all work better. We haven't gotten as far as testing this yet though.
> > > Jenn
> > > Epicor makes Crystal Reports 2008 SP3 runtimes available from their site, but I'm having weird issues with trying to format labels (we don't have/use bartender). I didn't have these issues w/ 8.03 and Crystal Reports XI.
> > > I tried the seagull drivers and I think I might continue to use them over the stock zebra drivers, but it didn't solve my formatting issues.
> > > So I installed SP4 runtimes directly from SAP. And now things works properly.
> > > Is anyone else running these runtimes? If so, any issues?
Yeah we are, they work fine.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Nov 17, 2011 at 4:17 PM, cubcrafters_it <
> properly.
Good to know. Did you patch up the Crystal Reports Designer too or just deploy the runtimes?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > properly.
Both but its backwards compatible either way.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Nov 17, 2011 at 5:08 PM, cubcrafters_it <
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> site,
> have/use
> over
> > > properly.
Jason,
Jenn
--- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@...> wrote:
Jenn,
--- In vantage@yahoogroups.com, "Jennifer" <Jennifer.Lisser@...> wrote:
> Jason,
> Jenn
Eric
> Jenn,
> > Jason,
> > Jenn
