APM & APM+ Discussion
I gave up on the upgrade since I had so little invested in the 2.5 install. A clean install of 2.6 went smoothly on my system...just waiting for the license keys from Altec now.
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
Sent: Monday, March 08, 2010 3:02 PM
Subject: [Vantage] Re: APM & APM+ Discussion
Uninstall APM 2.5
backup SQL db (if keeping)
Make sure you are running SQL 2005 or 2008
Install 2.6 making sure to denote which version you are upgrading from if you keep your db
Make sure you set activation account for COM+ application
I piloted upgrade several times and had times where SQL upgrade scripts did not complete - in which case I restored from backup and then ran the sql upgrade exe manually
a couple times I had duplicate ERM printers created which I had to delete from db manually
Good Luck
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Anyone run into issues upgrading from 2.5 to 2.6? I tried to follow the instructions but got a little lost pretty quickly and blew up my install (I'm not using it yet so not a big deal).
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of leannah
> Sent: Friday, March 05, 2010 4:12 PM
> The requested procedure document to create new document routings in APM - along with the use of customized e-mail subject lines and message body - has been uploaded to the group in the APM directory.
> Be sure you have version 2.6.467 build 36 patch 750 or above to use the new features.
> I hope it takes away a little of the mystery of APM.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Vantage 8.03.408A
I am looking to make contact, off list, with someone who has implemented APM. I say off list because I really would like to talk in order to get as much of the understanding as I can.
We installed (Epicor Consulting installed) close to two years ago. It never got off the ground. It has come up many times but I think we are done just bringing it up and want it in place.
The big push that we have is to utilize the email/fax options for purchasing.
If you have a few minutes and wouldn't mind giving me your insight and the steps taken, please shoot me an email and we can set a time.
Thanks.
Jeff
jlehr@...
I am well versed in the lost art of "APM".
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of jplehr
Sent: Thursday, February 25, 2010 1:00 PM
Subject: [Vantage] APM & APM+ Discussion
Vantage 8.03.408A
purchasing.
Thanks.
Jeff
jlehr@... <mailto:jlehr%40astromfg.com>
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.733 / Virus Database: 271.1.1/2708 - Release Date: 02/25/10
02:34:00
We delayed putting APM for two years and then only put it in to say we did it.
Users don't like it at all....the covering e-mail
does not contain any info of what the attachment
is about. Yes, you know it's a PO but you don't
know to what company or what the PO contains
without opening the attachment. Same with SO's
On top of the inadequacies of the message itself,
setting the software up and maintaing is a major
PITA. The maintenance is something right out of green-screen days.
Bob Carlson
Flanagan Industries
Although it's in, we don't use it. Users prefer
to copy the PO to a pdf and originate their own
eAt 01:00 PM 2/25/2010, you wrote:
>Vantage 8.03.408A
>Thanks.
>Jeff
><mailto:jlehr%40astromfg.com>jlehr@...
Ditto. There is nothing 'advanced' about it except the set-up procedure.
We don't use it either. Very disappointing.
Of Robert Carlson
Sent: Thursday, February 25, 2010 2:07 PM
Subject: Re: [Vantage] APM & APM+ Discussion
did it.
Bob Carlson
Flanagan Industries
>Vantage 8.03.408A
purchasing.
>Thanks.
>Jeff
There IS a way to fix up the subject line and body of the e-mail so it contains helpful information (and fax cover pages too). It is a bit of black magic but can be done - once you figure it out. You have to be on the 2.6.467 build 36 patch release 750 or above level. There was a bug with APM in regards to this feature but was fixed in that release level. I am working on a setup document so I can share with whomever would like the steps to putting a new document out in APM. Once you know the steps it is easy - like anything. I'll have something in a few days. If you'd like it I can post it to the site for all.
> Bob Carlson
> Flanagan Industries
> >Vantage 8.03.408A
> >Thanks.
> >Jeff
That would be most helpful and I would appreciate the assistance.
Bob Carlson
Flanagan Industries
bcarlson@...
>--- In
><mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com,
> > Bob Carlson
> > Flanagan Industries
> > >Vantage 8.03.408A
> > >Thanks.
> > >Jeff
Add me to the list for that document too !!
TIA
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Robert Carlson
Sent: Thursday, February 25, 2010 6:04 PM
Subject: Re: [Vantage] Re: APM & APM+ Discussion
Bob Carlson
Flanagan Industries
bcarlson@...
>--- In
> > Users don't like it at all....the covering e-mail does not contain
> > any info of what the attachment is about. Yes, you know it's a PO
> > but you don't know to what company or what the PO contains without
> > On top of the inadequacies of the message itself, setting the
> > software up and maintaing is a major PITA. The maintenance is
> > Bob Carlson
> > Flanagan Industries
> > Although it's in, we don't use it. Users prefer to copy the PO to a
> > pdf and originate their own eAt 01:00 PM 2/25/2010, you wrote:
> > >Vantage 8.03.408A
> > >time.
> > >Thanks.
> > >Jeff
I would definitely like to see that document.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of leannah
Sent: Thursday, February 25, 2010 5:42 PM
did it.
> Bob Carlson
> Flanagan Industries
> >Vantage 8.03.408A
purchasing.
> >Thanks.
> >Jeff
Version: 9.0.733 / Virus Database: 271.1.1/2710 - Release Date: 02/25/10
14:57:00
I would be interested as well.
John A. Hatcher
Manager of IS
Versa Products Co., Inc.
(201) 518-5948
(201) 843-2400 x4148
(201) 843-2931 (fax)
I'd be interested as well! J
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 295 or 870-480-4530
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Of Hatcher, John
Sent: Friday, February 26, 2010 7:17 AM
John A. Hatcher
Manager of IS
(201) 518-5948
Count me in.
Sent: Fri, February 26, 2010 8:23:07 AM
Subject: RE: [Vantage] Re: APM & APM+ Discussion
Â
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
Web Site: http://www.kerusso com
at: 800-424-0943
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Hatcher, John
To: vantage@yahoogroups .com
John A. Hatcher
Manager of IS
(201) 518-5948
I would love to see the document as well. Any tips on configuring this software would be great.
I have it installed, not live with it, although I do have some documents setup and working. Found the features to be very basic - I was disappointed once seeing it in action. Hopefully you can shed some light!
Thank You,
Bryan DeRuvo
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> Count me in.
> From: Matt Caldwell <matt@...>
> ÂÂ
> Matt Caldwell
> KERUSSO
> P.O. Box 32
> Fax: 870-423-3568
> at: 800-424-0943
> Of Hatcher, John
> John A. Hatcher
> Manager of IS
> (201) 518-5948
Bob,
Are you using APM 2.6? A lot of changes were made to the subject lines and the body of the email now allows the use of both HTML and Property Values so you know exactly what type of document it is and what is contained in it...standard HTML coding with variables, etc.
Another really nice feature is the fact that now you can select an outgoing email address for each routing group - so your POs could go from purchasing@...<mailto:purchasing@...> instead of a generic email address - that is still on by default, but now it is configurable.
If you are on maintenance with Epicor, you can obtain at no cost.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...<mailto:jason@...>
Uninstall APM 2.5
Good Luck
