APM: Only have property value captured on first page
Point 2 works a treat, but also if you use a primary decollation, it will keep
the document together and you can set a filter so it only sends a fax if the
details are in the format of 0*.
Sent: Tue, 19 July, 2011 19:00:04
Subject: RE: [Vantage] APM: Only have property value captured on first page
Â
Good Day Joe:
There are two ways to handle that.
First, there is a parameter that can be set to only read the 'space'
when a value changes - I do not know where it is - I suspect the
helpline would. If hepline cannot answer, I can give you a company to
call who would know.
Second - A solution that works sometimes. Print the Fax# on all the
pages in the same spot - print in White ink so is invisible. We never
actually tried it, but I remember hearing about it.
len.hartka@...
Of Joe Rojas
Sent: Tuesday, July 19, 2011 1:03 PM
Subject: [Vantage] APM: Only have property value captured on first page
Hello,
We are using APM to fax out our order acknowledgements.
The fax number is on the top of page one but does not exist on any
subsequent pages.
It seems that APM is reading all the pages and getting is reading some
like a part description as a fax number.
This is causing two faxes to go out one to the real fax number and one
to a fax number that is not a fax number.
Is there a way to only make is read from the first page?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
This e-mail and any attachments may contain proprietary and/or confidential
information. If you are not the intended recipient, please notify the sender
immediately by reply e-mail or at 410-472-2900 and then delete the message
without using, disseminating, or copying this message or any portion thereof.
With e-mail communications you are urged to protect against viruses.
Hello,
subsequent pages.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Good Day Joe:
len.hartka@...
Of Joe Rojas
Hello,
subsequent pages.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Give me a call offline and I can guide you through setting this up
properly... (717) 299-2361 x132
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Len Hartka
Sent: Tuesday, July 19, 2011 2:00 PM
page
Good Day Joe:
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Behalf
Of Joe Rojas
Hello,
subsequent pages.
