Auto login MES users
Bill,
Here's an easy way to do it in a mixed environment (where there are
regular Vantage users and MES users on the same server).
Copy the default.mfgsys file to MES.default.mfgsys
make the necessary auto-login edits (described in Scott's email below)
and save to the new file.
On each MES users Windows Environment tab (located in Active Direcotry
Users and Computers) have them run the following command:
<drive:>\client803\mfgsys -MES /config=MES.default.mfgsys
This will tell MES users to launch the MES using your new config file.
They will then still need to login with their employee ID, but this
should eliminate the need for them to put in a username and password
everytime they launch Vantage.
Hope this helps.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@... <blocked::mailto:jason@...>
Of hoomail4me
Sent: Saturday, January 05, 2008 10:58 AM
Subject: [Vantage] Re: Auto login MES users
In terminal services all users are using the same default.mfgsys file.
Bill
"Scott Litzau" <scott.litzau@...> wrote:
> Instead of using Single Sign-on. Edit the default.mfgsys file on the
MES
> unit and statically put in the Username and Password you wish the
MES Unit
> to use. Then when you run MES it will automatically sign in as that
user. I
> have seven different MES stations and I set up a user for each one,
MES1-7.
> This way in Admin Tools I can see which station is which when
looking at the
> sessions in case I need to delete a session.
> I do not use Terminal Services so I actually have mine set up to
> automatically log into Windows if the system is rebooted and then
have the
> MES program in the Startup Folder which start and automatically logs
in.
> Scott
All of our MES users use that same Windows and Vantage logon. Does
anyone know of a way to automate the login of an MES user so they
don't need to remmeber a password?
Note: All of our users access Vantage 8 through terminal services so I
cannot see how I can use the "SingleSignOn value="true" of the config
file. It would apply to all users.
Bill
If auto login will be truly of value to your company (based on some cost/benefit analysis), it seems you can either cough up the dough for a sufficient (presumably small - like 1-3) PCs or set up a 2nd terminal server for MES users.
Either should allow you to set up the config files for singlesignon=true for these specific user cases.
Question though: How will single sign on for MES users really help?
My understanding is that MES takes a single user login (that if I recall correctly, is an MES provided default user) and then, within MES, different employees (set up in Vantage) still have to 'clock in' to report activity.
Are all of your MES users going to do activity reporting under a single (or small few - like 2-4) role oriented vantage 'employee' entities?
If not, I don't understand the potential benefit.
Am I missing something? My understanding of it might be flawed so I'd also appreciate any related real world experiences from anyone in the group that might clarify the nuances of this aspect of MES better (for both Bill, myself, and perhaps others).
Rob Brown
Bill
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Instead of using Single Sign-on. Edit the default.mfgsys file on the MES
unit and statically put in the Username and Password you wish the MES Unit
to use. Then when you run MES it will automatically sign in as that user. I
have seven different MES stations and I set up a user for each one, MES1-7.
This way in Admin Tools I can see which station is which when looking at the
automatically log into Windows if the system is rebooted and then have the
MES program in the Startup Folder which start and automatically logs in.
Scott
Robert Brown
Sent: Wednesday, January 02, 2008 10:40 PM
Subject: Re: [Vantage] Auto login MES users
for MES users.
Rob Brown
Bill
Yahoo! Groups Links
You can have different config files for the same database. Make a
copy of the default and name it something else like MES. Then make
your changes & set the path for the MES users.
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
the MES
MES Unit
that user. I
one, MES1-7.
looking at the
have the
logs in.
> Scott
Behalf Of
> Robert Brown
for a
terminal server
> for MES users.
singlesignon=true
help?
I recall
different
activity.
single
entities?
so I'd also
group that
Bill,
> Thanks
> Rob Brown
logon. Does
so I
config
> Thanks,
> Bill
Yahoo! Search.
must have
Builder and
> Yahoo! Groups Links
Bill,
My impression of what you are looking for is this...
You have users set up in the system to apply security to MES users (link the
Shop Employee to link to a user account).
Then you are looking to allow these Shop Employees to log into MES using
their "Shop Employee", "ID" and have it apply the security based on their
User account and not require a password after they enter their "ID".
If that is what you are looking for, I am also looking for the same thing.
It exists in 6.1 as a checkbox on the User account "DC Password Req". If
you left the box unchecked, they user was not required to enter a password
(except to set an initial password) when they log into Shop floor (6.1
Version of MES).
If I am correct in what you are looking for, one of us should create an
enhancement request and the other attach themselves to it.
Now as to calling it an enhancement request to request a feature be added
back that existed in the past, that I won't get into. :)
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
hoomail4me
Sent: Wednesday, January 02, 2008 10:22 PM
Subject: [Vantage] Auto login MES users
Bill
In addition, you can setup a RDC connection-specific shortcut that MES users launch (THEY RUN MES THROUGH INTO TS) where it's configured it to automatically launch MES and therefore they do not need to do anything other than run the connection shortcut for Terminal Server access.
Carey
To: vantage@yahoogroups.comFrom: scott.litzau@...: Thu, 3 Jan 2008 08:20:20 -0600Subject: RE: [Vantage] Auto login MES users
Instead of using Single Sign-on. Edit the default.mfgsys file on the MESunit and statically put in the Username and Password you wish the MES Unitto use. Then when you run MES it will automatically sign in as that user. Ihave seven different MES stations and I set up a user for each one, MES1-7.This way in Admin Tools I can see which station is which when looking at thesessions in case I need to delete a session.I do not use Terminal Services so I actually have mine set up toautomatically log into Windows if the system is rebooted and then have theMES program in the Startup Folder which start and automatically logs in.Scott -----Original Message-----From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf OfRobert BrownSent: Wednesday, January 02, 2008 10:40 PMTo: vantage@yahoogroups.comSubject: Re: [Vantage] Auto login MES usersIf auto login will be truly of value to your company (based on somecost/benefit analysis), it seems you can either cough up the dough for asufficient (presumably small - like 1-3) PCs or set up a 2nd terminal serverfor MES users.Either should allow you to set up the config files for singlesignon=truefor these specific user cases. Question though: How will single sign on for MES users really help? My understanding is that MES takes a single user login (that if I recallcorrectly, is an MES provided default user) and then, within MES, differentemployees (set up in Vantage) still have to 'clock in' to report activity.Are all of your MES users going to do activity reporting under a single(or small few - like 2-4) role oriented vantage 'employee' entities?If not, I don't understand the potential benefit.Am I missing something? My understanding of it might be flawed so I'd alsoappreciate any related real world experiences from anyone in the group thatmight clarify the nuances of this aspect of MES better (for both Bill,myself, and perhaps others).ThanksRob Brownhoomail4me <hoomail4me@...> wrote:All of our MES users use that same Windows and Vantage logon. Doesanyone know of a way to automate the login of an MES user so theydon't need to remmeber a password?Note: All of our users access Vantage 8 through terminal services so Icannot see how I can use the "SingleSignOn value="true" of the configfile. It would apply to all users.Thanks,Bill ---------------------------------Looking for last minute shopping deals? Find them fast with Yahoo! Search.[Non-text portions of this message have been removed]Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must havealready linked your email address to a yahoo id to enable access. )(1) To access the Files Section of our Yahoo!Group for Report Builder andCrystal Reports and other 'goodies', please goto:http://groups.yahoo.com/group/vantage/files/. (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages(3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links Yahoo! Groups Links
_________________________________________________________________
Share life as it happens with the new Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_122007
Yes, I don't want the password requirement for MES user.
Bill
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Bill,
(link the
their
thing.
Req". If
password
> Version of MES).
added
> Aaron Hoyt
> Vantage Plastics
Michael, now why didn't I think of that - staring me right in the face!
Providing the correct username and password to MES users you would
think would be a non-issue but in a manufacturing environment with 100
MES users, some with no-computer experience, some with language
barriers, an auto logon is the way to go.
Thanks to all for your input...
Bill
--- In vantage@yahoogroups.com, "Michael McWilliams"
> --- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@>
Bill
MES Unit
user. I
MES1-7.
looking at the
have the
> Scott
