Auto logon for Terminal Server Clients
Thank you Brian. This worked just fine as soon as I put in the
mfg.exe.
Kelly
--- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@c...>
wrote:
> We do have the Plant Floor interface lauching automatically through
> some Terminal Server and Remote Desktop Connection icons.
> We have the following in our program path.
> v:\mfgsys61\mfg.exe v:\mfgsys61\tsplantfloor.mfg
> I think the important thing that you're missing is the launch of
> mfg.exe. It isn't obvious that you need to do that and took a
while
> for us to figure out, but when we did it starting working. Calling
> the .mfg file itself isn't enough.
> HTH,
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, "Rebecca Schmuck" <rschmuck@p...>
> wrote:
> > I wasn't able to do it through RDC either, but you can do it
under
> the
> > Environment tab for each remote user and that seems to work fine.
> > -----Original Message-----
> > From: krobertson4 [mailto:krobertson4@y...]
> > Sent: Wednesday, April 13, 2005 9:35 AM
> > Subject: [Vantage] Auto logon for Terminal Server Clients
> > We are trying to get the auto logon to work with our Terminal
> Server. We
> > have a network drive mapped for Vantage in our normal logon
> script. The
> > drive maps as "V". On the Program tab on the Remote Desktop
> Connedction, I
> > have the following:
> > Under "Start the following Program on connection" V:\BMKR61.MFG
> Under
> > "Program path and file name" V:\
> > I get the following error:
> > An error (193)occured while creating user logon.
> > This initial program connot be started: V:\MMKR61.MFG Please
> consult help
> > for more information
> > I have tried many different options here and keep getting the
same
> error
> > code (193) no matter what I put in. The only difference is
> the "This
> > initial program...." will be different, depending upon what I
have
> typed in.
> > We want to do this so that the users can not "accidently"
shutdown
> the
> > server. The will just see the vantage program and when the log
out
> the
> > Terminal Server connection will close completely.
> > If anyone has successfully accomplished this, please advise how
you
> did
> > this...please.
> > We are using Windows Terminal Server 2003.
> > Thank you in advance.
> > Kelly
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
> > already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
Server. We have a network drive mapped for Vantage in our normal
logon script. The drive maps as "V". On the Program tab on the
Remote Desktop Connedction, I have the following:
Under "Program path and file name" V:\
Please consult help for more information
I have tried many different options here and keep getting the same
error code (193) no matter what I put in. The only difference is
the "This initial program...." will be different, depending upon what
I have typed in.
We want to do this so that the users can not "accidently" shutdown
the server. The will just see the vantage program and when the log
out the Terminal Server connection will close completely.
If anyone has successfully accomplished this, please advise how you
did this...please.
Kelly
I wasn't able to do it through RDC either, but you can do it under the
We are trying to get the auto logon to work with our Terminal Server. We
have a network drive mapped for Vantage in our normal logon script. The
drive maps as "V". On the Program tab on the Remote Desktop Connedction, I
have the following:
Under "Start the following Program on connection" V:\BMKR61.MFG Under
This initial program connot be started: V:\MMKR61.MFG Please consult help
I have tried many different options here and keep getting the same error
code (193) no matter what I put in. The only difference is the "This
initial program...." will be different, depending upon what I have typed in.
We want to do this so that the users can not "accidently" shutdown the
server. The will just see the vantage program and when the log out the
If anyone has successfully accomplished this, please advise how you did
this...please.
Kelly
Yahoo! Groups Links
mfg.exe. It isn't obvious that you need to do that and took a while
HTH,
Brian Stenglein
Clow Stamping Co.
the
Server. We
script. The
Connedction, I
> have the following:
Under
consult help
error
the "This
typed in.
the
the
did
> this...please.
> Kelly
must have
Builder and
> Yahoo! Groups Links
There's a setting, not sure where, to disallow "Restart" and "Shut Down",
for all but network administrators, if you like.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, April 13, 2005 7:35 AM
> I have typed in.
> did this...please.
> Kelly
> (3) To view links to Vendors that provide Vantage services goto: http://gr
> Yahoo! Groups Links
On the Terminal Server under Administrative tools \ Local Security
Settings \ Local Policy \ User Right Assignment \ Shut down the system
you can add only the user you want to have the rights to Shut down or
restart the system.
Hope this helps.
_____
Sent: Wednesday, April 13, 2005 1:47 PM
Subject: Re: [Vantage] Auto logon for Terminal Server Clients
Down",
> I have typed in.
> did this...please.
> Kelly
and
http://gr
> Yahoo! Groups Links
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
