Hi,
So I have setup auto print for the material queue using data directives. It is working fine, However, I have a small problem:
When you manually choose print from the material queue dashboard you have a choice to add all selected lines with the same order number to 1 printed sheet. “Break On”
So, My question is. Is it possible to do this on auto print?
I’ve tried to ADD “OrderNum” to the Pagebreak option. However, it still prints each one on a different page.
It seems that the option I wont is greyed out. “Once passing all matching rows”
Thanks in advance.
