BAQ Report and Report Style in Kinectic 2021
Hello,
I have BAQ Report, when I add field in BAQ I use Sync Dataset in Report Style for update BAQ Report, but Kinectic 2021 doesn’t exist this button. What alternatives does Kinectic 2021 have to update the BAQ Report when it added a new field in the BAQ?
Thanks for you answer.
Consider yourself lucky. Pressing that button can cause more harm than help (more so with RDD based Reports).
You will have to edit the Query Expression in the reports RDL file (using SRS Report Builder). Add the ne field in the SELECT clause, then Add a Query field to the dataset.
Edit
See: the following for more details:
Hello @ckrusen ,
thank you for your answer. Regards.
