BAQ Report and Report Style in Kinectic 2021
Consider yourself lucky. Pressing that button can cause more harm than help (more so with RDD based Reports).
You will have to edit the Query Expression in the reports RDL file (using SRS Report Builder). Add the ne field in the SELECT clause, then Add a Query field to the dataset.
Edit
See: the following for more details:
