Bartender Upgrade- Unable to print labels due to data fields missing
We are trying to upgrade our Bartender server. When testing to print labels it gives an error of not being able to the data fields. The integrations are set up as the previous bartender version. Does anyone now if I am missing a step that has to do with Epicor specific or anything else.
Hello @jhmwm,
Wondering if you were able to correct this issue. We just upgraded from 2022 R4 to R7 and now we are receiving the same error.
The following database fields are referenced by template objects but are not present in the database. Proceed with empty values for these fields?
If you upgrade bartender, make sure you open your old label designs in the NEW designer, make any adjustments and save. Them, you should od be prompted with something like “You are saving on an old version of bartender do you wish to save in the latest version” or similar. Your integrations should work after that.
