BOSecMRUList Blank Title 100940
I get the error when I try to log into the system. The error seems to appear after a user gets locked up in the system and you have to end task the session. I am able to login as another user and switch to that user with no issue and then when I start a new session I am OK to login with that user account. It is very weird! I can actually replicate this error on different work stations and databases.
Thanks, Jason
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Wednesday, June 01, 2011 9:12 AM
Subject: Re: [Vantage] BOSecMRUList
When are you getting this error? We are 9.5.604 and have no priblems.
*Jose C Gomez*
*Software Engineer*
CHECK OUT MY NEW BLOG <http://www.usdoingstuff.com> OR CONTACT ME DIRECTLY*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, Jun 1, 2011 at 9:07 AM, Jason Moyer <jmoyer@...> wrote:
> Has anyone else seen the below error and possible know how to correct
> the error? I get this error when I try to log into the system as the
> manager account. It will display this error and then exit the system.
> I have called support and they have been worthless and actually closed
> the ticket without a resolution. This is very frustrating and any help
> would be greatly appreciated.
> We are running Epicor 905.604A. If anyone out there is thinking about
> updating to this release DON'T. I have had nothing but issues since I
> installed the 604 patch. The issues have been anything from general
> functionality not working to huge performance issues.
> Error Detail
> Unable to find a writable directory for files of type 'BOSecMRUList'.
> Stack Trace
> at Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.BuildPath(Session
> session, String fileType, Boolean allUsers, Boolean includeVersion) at
> Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.GetOrCreatePathFromPa
> ths(IList`1 paths, Session session, String fileType, Boolean allUsers,
> Boolean
> includeVersion)
> at Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.GetPath(Session
> Epicor.Mfg.UI.SecRights.SecRightsHandler.BOSecMRUList..ctor(Session
> Session)
> at Epicor.Mfg.UI.SecRights.SecRightsHandler.CacheBOSecSettings(Session
> Session)
> at Epicor.Mfg.UI.Startup.ReStart(Session session) at
> Epicor.Mfg.UI.MenuForm.addSessionToCollection(Session session) at
> Epicor.Mfg.UI.MenuForm..ctor(Launch launcher, Session initialSession,
> String menuID, LicenseType initialLicType) at
> Epicor.Mfg.UI.App.Launch.createInitialSession()
> at Epicor.Mfg.UI.App.Launch.ShowMenuForm()
> at Epicor.Mfg.UI.App.Launch.ShowDialog(String[] args)
Has anyone else seen the below error and possible know how to correct the error? I get this error when I try to log into the system as the manager account. It will display this error and then exit the system. I have called support and they have been worthless and actually closed the ticket without a resolution. This is very frustrating and any help would be greatly appreciated.
We are running Epicor 905.604A. If anyone out there is thinking about updating to this release DON'T. I have had nothing but issues since I installed the 604 patch. The issues have been anything from general functionality not working to huge performance issues.
Error Detail
Stack Trace
at Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.BuildPath(Session session, String fileType, Boolean allUsers, Boolean includeVersion)
at Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.GetOrCreatePathFromPaths(IList`1 paths, Session session, String fileType, Boolean allUsers, Boolean includeVersion)
at Epicor.Mfg.UI.FrameWork.FileExtensionMapProvider.GetPath(Session session, String fileType, Boolean allUsers, Boolean includeVersion)
at Epicor.Mfg.UI.SecRights.SecRightsHandler.BOSecMRUList..ctor(Session Session)
at Epicor.Mfg.UI.SecRights.SecRightsHandler.CacheBOSecSettings(Session Session)
at Epicor.Mfg.UI.MenuForm.addSessionToCollection(Session session)
at Epicor.Mfg.UI.MenuForm..ctor(Launch launcher, Session initialSession, String menuID, LicenseType initialLicType)
at Epicor.Mfg.UI.App.Launch.createInitialSession()
*Jose C Gomez*
*Software Engineer*
E: jose@...
> appreciated.
> Error Detail
> Stack Trace
> at
> includeVersion)
> Session)
> Session)
