Break buzzer Blank Title 104427
My time clock system (non-Epicor) has the option to control relays that ring the bells on a schedule.
--- In vantage@yahoogroups.com, "RandyD" <randy.duly@...> wrote:
> How do you have everything connected at your place? How did you connect the buzzer?
> --- In vantage@yahoogroups.com, "sbraudrick@" <sbraudrick@> wrote:
> > Are all of your machines/servers, including whatever controls the buzzers, synced to the same NTP server? If not, that might be your problem. If so, perhaps check the scheduled sync intervals, there's plenty of information out there via Google. Also make sure the "Windows Time" service (assuming Windows) is running on all machines.
> > I hope that helps,
> > SB
> > --- In vantage@yahoogroups.com, Nelson Dufour <ndufour@> wrote:
> > > Hi all,
> > > Having a problem syncing our break alarms with the MES station times.
> > > Any suggestions greatly appreciated.
> > > Thanks,
> > > Nelson L. Dufour
> > > I.S. Services Mgr.
> > > 1691 Walker Rd.
> > > Windsor, ON. N8W 3P1
> > > 519-253-2461 313-965-8680
> > > Fax: 519-253-5911
Hi all,
Nelson L. Dufour
I.S. Services Mgr.
1691 Walker Rd.
Fax: 519-253-5911
I hope that helps,
SB
--- In vantage@yahoogroups.com, Nelson Dufour <ndufour@...> wrote:
> Hi all,
> Thanks,
> Nelson L. Dufour
> I.S. Services Mgr.
> 1691 Walker Rd.
> Fax: 519-253-5911
> I hope that helps,
> SB
> > Hi all,
> > Thanks,
> > Nelson L. Dufour
> > I.S. Services Mgr.
> > 1691 Walker Rd.
> > Fax: 519-253-5911
