Once an ASM has been entered, and routing saved in Job Entry, is there anyway to “unlock” the Op Seq number if you need to add operations or move around the order? Currently our only option (if we run out of room in between Ops) is to use Job adjustment to force an operation closed and add the new ops after, or add the operations out of sequence…
Thanks!
