Clock Time VS. Labor Time Report
"Weird" was the only way I could describe it because I wasn't sure what was happening myself. The only thing I've noticed so far is that the pay hours will total differently each day for some employees if I do a report that includes all of the employees vs. a report that only includes the individual employee. Why this would effect an individual's total pay hours for a given day is beyond me . . . much like this entire report is!
But let me see if I can explain what I've got:
This is a BAQ Report. I have two groups, the first being LaborHed.EmployeeNum the second being LaborHed.PayrollDate. In the details section I have LaborHed.PayHours and LaborDtl.LaborHrs, but I have hidden this section because I don't need these results to be visible. In the footer for group 2 (payrolldate) I have the running total for payhours and a summary of laborhrs. The running total is comprised like this: Field to summarize: LaborHead.PayHours as a sum; Evaluated on change of field LaborHed.LaborHedSeq; being reset on change of field LaborHed.PayrollDate.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> "Weird"? Check your crystal formulas and links between tables in
> Crystal, make sure you aren't counting a record twice or excluding it
> with a too restrictive join.
> The other possibility is unusual data... is the labour still active, so
> the end time is not valid yet (check ActiveTrans & TimeStatus)? Are you
> trying to manually adjust for lunch/breaks/absences? Are people
> temporarily loaned to other depts, so employee & labordtl JCDept don't
> match when you expect them to? (Making some guesses as to what you're
> doing, might be on the wrong track).
> Brian.
> Of Sean Toler
> Sent: Monday, August 08, 2011 9:33 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Clock Time VS. Labor Time Report
> I spoke too soon. I'm getting some weird pay hour totals here and there
> and I'm not sure why.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Sean Toler" <seantoler@> wrote:
> > That worked so well it brought a tear to my eye!
> > Thanks again!
> > > Ooooh! OK, gotcha! Thanks again!
> "Brian Roberts" <broberts@> wrote:
> > > > To do this task in Crystal: "only add hours on LaborHed on change
> of
> > > > LaborHedSeq" ... do this: create a running total field, and have
> it
> > > > evaluate only on "change of field" (or possibly "change of
> group").
> > > > Then manually add that field to your report.
> > > > The "insert summary" option in Crystal makes the wrong assumptions
> for
> > > > this calculation.
> > > > Brian.
> > > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > > > Of Sean Toler
> > > > Sent: Thursday, August 04, 2011 11:22 AM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > This is still giving me some trouble. Would you mind elaborating a
> bit
> > > > more please? Thanks.
> > > > > Thank you very much! I will go and give that a try when I get
> some
> > > > time. It's interesting that you mentioned someone clocking out and
> back
> > > > in on the same day because that was the first problem I started
> having
> > > > with this report!
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> > > > "al2trace" <allen.larsen@> wrote:
> > > > > > The field that uniquely ties LaborHed and LaborDtl together is
> > > > LaborHedSeq. Grouping on payroll date will work for many
> transactions
> > > > but not when someone punches out and then back in on the same day.
> If
> > > > you need to group on the day, you will need to be careful how you
> sum
> > > > the header records. Your final group level should be LaborHedSeq
> and
> > > > then only add hours on LaborHed on change of LaborHedSeq.
> > > > > > > Hello.
> > > > > > > I am attempting to create a report for management that
> compares an
> > > > employee's clock time to his/her labor time. I am using
> > > > LaborDtl.LaborHrs and LaborHed.PayHrs for this. My problem arises
> when I
> > > > try to get a sum of the hours. I have grouped by employee # and
> then by
> > > > Payroll Date. When I do a sum of the labor hours and place it in
> the
> > > > footer of the payroll date group the sum is correct. However, when
> I do
> > > > the same thing for pay hours, I am getting some off the wall sums.
> > > > Anyone have any suggestions to correct this?
> > > > [Non-text portions of this message have been removed]
Hello.
I am attempting to create a report for management that compares an employee's clock time to his/her labor time. I am using LaborDtl.LaborHrs and LaborHed.PayHrs for this. My problem arises when I try to get a sum of the hours. I have grouped by employee # and then by Payroll Date. When I do a sum of the labor hours and place it in the footer of the payroll date group the sum is correct. However, when I do the same thing for pay hours, I am getting some off the wall sums. Anyone have any suggestions to correct this?
The field that uniquely ties LaborHed and LaborDtl together is LaborHedSeq. Grouping on payroll date will work for many transactions but not when someone punches out and then back in on the same day. If you need to group on the day, you will need to be careful how you sum the header records. Your final group level should be LaborHedSeq and then only add hours on LaborHed on change of LaborHedSeq.
--- In vantage@yahoogroups.com, "Sean Toler" <seantoler@...> wrote:
> Hello.
Thank you very much! I will go and give that a try when I get some time. It's interesting that you mentioned someone clocking out and back in on the same day because that was the first problem I started having with this report!
> --- In vantage@yahoogroups.com, "Sean Toler" <seantoler@> wrote:
> > Hello.
This is still giving me some trouble. Would you mind elaborating a bit more please? Thanks.
> > > Hello.
To do this task in Crystal: "only add hours on LaborHed on change of
LaborHedSeq" ... do this: create a running total field, and have it
evaluate only on "change of field" (or possibly "change of group").
The "insert summary" option in Crystal makes the wrong assumptions for
this calculation.
Brian.
Of Sean Toler
with this report!
> > > Hello.
> this calculation.
> Brian.
> Of Sean Toler
> with this report!
> > > > Hello.
Thanks again!
> > this calculation.
> > Brian.
> > Of Sean Toler
> > with this report!
> > > > > Hello.
I spoke too soon. I'm getting some weird pay hour totals here and there and I'm not sure why.
> Thanks again!
> > > this calculation.
> > > Brian.
> > > Of Sean Toler
> > > with this report!
> > > > > > Hello.
Brian.
Of Sean Toler
> Thanks again!
of
it
group").
for
> > > this calculation.
> > > Brian.
Behalf
> > > Of Sean Toler
bit
some
back
having
> > > with this report!
transactions
If
sum
and
> > > > > > Hello.
compares an
when I
then by
the
I do
