Constrained Materials & Job Scheduling - Vantage 8.03.305K
My apologies. When we started on Vantage in 8.0, what I said was
true. It did not take long for us to decide we would not use the
Constrained Material checkbox because everything bought to a job was
considered constrained regardless of the checkbox. We are on 404 now
and you are right that it is grayed out. I checked with Support and
somewhere around 8.03 it became necessary to have APS for that
feature. Sorry I didn't check first.
-Peter
--- In vantage@yahoogroups.com, tblakely@... wrote:
> Until we purchased APS the constrained material checkbox was greyed
out.
> Once we turned on APS it became available.
> "pvolkert365"
<pvolkert@symetri
cs.com> To
> Sent by:
vantage@yahoogrou cc
ps.com
Subject
> [Vantage] Re: Constrained
Materials
> 05/30/2008 02:57 & Job Scheduling - Vantage
8.03.305
> PM
K
> Please respond
to
vantage@yahoogrou
ps.com
> You don't need APS for the Constrained Material feature, however
if
> you are buying to jobs, your selection is overridden and
everything
> is considered
constrained.
Peter
> --- In vantage@yahoogroups.com, "jpfinch1" <sway@>
wrote:
> > I was lead to believe that the constrained material flag only
works
> > it you purchased the APS "Advanced Planning & Scheduling"
module.
> > --- In vantage@yahoogroups.com, Robert Brown
<robertb_versa@>
wrote:
> > > It doesn't work in 404B either (and, good riddance) - It's one
of
> > those nice sales pitch features that, in practical use, would
be
much
> > more trouble than any productive value it would
add.
> > > Perhaps if Constrained was controlled at the PartPant (or
better
> > yet, PartWhse) level - rather than at the Part level (impacting
all
> > Plants), it would have some chance of being
useful.
> > > Probably some out there have also found that it wreaks havoc
with
> > MRP and the Global Scheduler (which are Plant-
centric).
> > > The view used in the application is a temp view that draws
from
> > several 'real' tables. I suspect the assembly method to
construct
the
> > view on the fly is just flawed and never actually brings in
the
> > Part.Constrained status of the JobMtl.PartNum's - OR the
display
> > filter code for the native grid control is flawed in
some
fundamental
way.
> > > Rob
Brown
> > > --- On Thu, 5/29/08, nmtaylor1969 <n.taylor@>
wrote:
> > > From: nmtaylor1969
<n.taylor@>
> > > Subject: [Vantage] Constrained Materials & Job Scheduling -
Vantage
8.03.305K
> > > To:
> > > Date: Thursday, May 29, 2008, 9:45
AM
Hi,
> > > We want to use the constrained material flag and lead time
value
within
> > > the MPF to control the initial scheduling dates of jobs.
Our
business
> > > is very material orientated and there is no point scheduling
jobs
if
> > > materials are unavailable. We plan to use this for "A" class
and
> > > problem parts only. After setting the appropriate parameters
and
> > > running MRP, the new unfirm job suggestions appear
to
> > > take the specified raw material lead times into account,
however
when
> > > we look at the detail tab within the job scheduling board,
the
material
> > > constraints grid is blank. Does anyone know why this
is ??
> > > Nick
Taylor
> > > Kingfield Electronics
Limited
Hi,
We want to use the constrained material flag and lead time value within
the MPF to control the initial scheduling dates of jobs. Our business
is very material orientated and there is no point scheduling jobs if
materials are unavailable. We plan to use this for "A" class and
problem parts only. After setting the appropriate parameters and
running MRP, the new unfirm job suggestions appear to
take the specified raw material lead times into account, however when
we look at the detail tab within the job scheduling board, the material
constraints grid is blank. Does anyone know why this is ??
Nick Taylor
Kingfield Electronics Limited
It doesn't work in 404B either (and, good riddance) - It's one of those nice sales pitch features that, in practical use, would be much more trouble than any productive value it would add.
Perhaps if Constrained was controlled at the PartPant (or better yet, PartWhse) level - rather than at the Part level (impacting all Plants), it would have some chance of being useful.
Probably some out there have also found that it wreaks havoc with MRP and the Global Scheduler (which are Plant-centric).
The view used in the application is a temp view that draws from several 'real' tables. I suspect the assembly method to construct the view on the fly is just flawed and never actually brings in the Part.Constrained status of the JobMtl.PartNum's - OR the display filter code for the native grid control is flawed in some fundamental way.
Rob Brown
--- On Thu, 5/29/08, nmtaylor1969 <n.taylor@...> wrote:
Subject: [Vantage] Constrained Materials & Job Scheduling - Vantage 8.03.305K
Date: Thursday, May 29, 2008, 9:45 AM
Hi,
Nick Taylor
Thanks Rob, I guess I will give it up as a bad job then!!
I presume if we just set the lead times within the MRP planning
parameters this will get us to where we need to be. It would have
been useful to us to highlight those materials which are the key
drivers of the lead time.
I agree with your comments about the sales pitch! ;o)
I take it you are running 8.03.4xx - I have heard that this buggy,
particularly in relation to MRP. Are you encountering problems ?
Nick
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
way.
> Rob Brown
> From: nmtaylor1969 <n.taylor@...>
8.03.305K
> Hi,
within
business
if
when
material
> Thanks,
> Nick Taylor
I was lead to believe that the constrained material flag only works
it you purchased the APS "Advanced Planning & Scheduling" module.
way.
> Rob Brown
8.03.305K
> Hi,
within
business
if
when
material
> Thanks,
> Nick Taylor
You don't need APS for the Constrained Material feature, however if
you are buying to jobs, your selection is overridden and everything
is considered constrained.
-Peter
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
much
the
fundamental
> way.
> > Rob Brown
> > --- On Thu, 5/29/08, nmtaylor1969 <n.taylor@> wrote:
> > From: nmtaylor1969 <n.taylor@>
Vantage
> 8.03.305K
> > Hi,
> within
> business
> if
> when
> material
> > Thanks,
> > Nick Taylor
I'll let you know after 6/9 if we overcame all the (new) 404 scheduling and MRP issues. We're piloting (and customizing/putting BAMs & BPMs in place like mad to get around the problems) so I'm hopeful it will be smooth.
- But yes: 403/4 were steps backwards in some VERY critical areas (to support our particular business model & subprocesses).
Rob
--- On Fri, 5/30/08, nmtaylor1969 <n.taylor@...> wrote:
Subject: [Vantage] Re: Constrained Materials & Job Scheduling - Vantage 8.03.305K
Date: Friday, May 30, 2008, 2:55 AM
Nick
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
MRP and the Global Scheduler (which are Plant-centric) .
Part.Constrained status of the JobMtl.PartNum' s - OR the display
way.
> Rob Brown
> --- On Thu, 5/29/08, nmtaylor1969 <n.taylor@.. .> wrote:
> From: nmtaylor1969 <n.taylor@.. .>
8.03.305K
> To: vantage@yahoogroups .com
> Hi,
within
business
if
when
material
> Thanks,
> Nick Taylor
We have APS and on 404 it is a useless function relative to simply having skilled, experienced planners who don't need the system to do what they do in the blink of an eye in their heads.
It is a fundamentally flawed 'book' concept as there is (rarely) a true fixed "lead time" for a part in the real world. That's why we pay buyers and planners - to improve those lead times. Why any one would want a system to codify them is beyond me.
Rob
Date: Friday, May 30, 2008, 9:46 AM
way.
> Rob Brown
8.03.305K
> Hi,
within
business
if
when
material
> Thanks,
> Nick Taylor
Until we purchased APS the constrained material checkbox was greyed out.
"pvolkert365"
<pvolkert@symetri
cs.com> To
Sent by: vantage@yahoogroups.com
ps.com
Subject
05/30/2008 02:57 & Job Scheduling - Vantage 8.03.305
PM K
Please respond to
vantage@yahoogrou
ps.com
-Peter
much
the
fundamental
> way.
> > Rob Brown
Vantage
> 8.03.305K
> > Hi,
> within
> business
> if
> when
> material
> > Thanks,
> > Nick Taylor
The concept of having stronger buyers / planners and not building in
failure is definitely the right way to go. A significant part of our
ERP implementation process ( having moved away from home grown
software ) is the culture change that goes with the move to a new
system and a new way of doing things. This never really hits you
until along way into the implementation process, as you realise that
changing the system and not cultivating the people wont achieve
anything and will yield the same poor results as before but just on a
different platform.
I think we will use some lead time parameters for the really nasty
parts and leave everything else for the time being. At least that
will help with the initial scheduling process.
Nick Taylor
> Rob
> From: jpfinch1 <sway@...>
Vantage 8.03.305K
much
the
fundamental
> way.
> > Rob Brown
> > --- On Thu, 5/29/08, nmtaylor1969 <n.taylor@ .> wrote:
> > From: nmtaylor1969 <n.taylor@ .>
Vantage
> 8.03.305K
> > Hi,
> within
> business
> if
> when
> material
> > Thanks,
> > Nick Taylor
