Consumable items
Some ideas:
Create a seperate warehouse for consumables.
Make each item non-netable.
Don't bother with issueing anything.
When reordering an item, do one adjustment to zero.
Just my 2 cents...
Rick G.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Stephen Freeman
Sent: Thursday, October 27, 2005 2:14 PM
To: Vantage E Group (E-mail)
Subject: [Vantage] consumable items
Scope of Problem
Consumable items such as drill bits, paper, sanding belts, toilet paper,
ect... are received into Inventory. At some point they are physically
picked up by people who require them (Custodial personnel, Tool Crib
Manager, office personnel) and used. These items are not connected to a
job
so a Quantity Adjustment is done in Vantage to reflect these items being
used. This doesn't always happen, in fact our past performance is pretty
bad on these items.
Is there a better way of handling these items than having to do Quantity
Adjustments every time we issue paper?
Scope of Problem
Manager, office personnel) and used. These items are not connected to a job
bad on these items.
Not sure which version of Vantage you're on (and I'm still new to Vantage)
but there's a non-computer way that I have seen frequently. It's just a
simple reorder card/ticket/sticky-note. Calculate the quantity that triggers
a reorder for that item and place the reorder card on that box/container or
at the bottom of the bin. When the ticket comes up while consuming the
material, it is dropped into purchasing's inbox. It also helps to write a
number on each container so that they are used in order (FIFO usually) so
the reorder tag doesn't come up too early.
It works well and it doesn't kill your Vantage session. ;-)
Mark W.
We do much the same thing, however they get adjusted out in batches. We can
ID these item by part number format from the inventory report. then once a
month accounting adjusts them out as an expense for that month.
the actual inventory is monitored out side of the Vantage world.
Sent: Thursday, October 27, 2005 1:14 PM
Scope of Problem
bad on these items.
SPONSORED LINKS
Manufacturing software Membership database software Database mortgage
software
Pda database software Database management software Database marketing
software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
If you are not actually tracking them why are they in inventory? Why not
just received them against a PO, charge them to overhead when received, and
let the responsible personnel keep track of the reorder point and issue a PO
requisition. You then monitor usage at the requisition point prior to PO
issuance.
Roger Colglazier
Stephen Freeman
Scope of Problem
bad on these items.
Yahoo! Groups Links
Another option for MRO or consumable items is a two bin system. You can
establish a primary bin (drawer, cabinet, etc.) that you do your normal
issues from. Then calculate your reorder point (your normal demand over
lead time plus some safety stock) and place that in a secondary
location. When the primary location is empty and you need to issue from
the secondary one, you move the total quantity from the secondary
location into the primary and then that is your trigger to reorder. You
can keep track of the inventory inside Vantage but the physical
existence of the secondary bin gives you an insurance policy for when
transactions don't always take place.
Bob D.
Of Mark Wonsil
Sent: Thursday, October 27, 2005 2:31 PM
Subject: RE: [Vantage] consumable items
Quantity
Vantage)
triggers
or
a
so
Mark W.
YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/vantage> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
what version of Big V lets you do that? We're on 5.0 and cant use the req
system for anything except job materials(?)
Sent: Thursday, October 27, 2005 1:36 PM
issuance.
Roger Colglazier
Stephen Freeman
Scope of Problem
bad on these items.
Yahoo! Groups Links
SPONSORED LINKS
software
software
_____
YAHOO! GROUPS LINKS
on the web.
_____
Wow..., we just wheel the grocery cart up to the shelves and shovel. Kind
of like supermarket sweep. Then new stuff magically reappears, or is beamed
in.
Shirley
_____
Robert Dillon
Sent: Thursday, October 27, 2005 2:45 PM
Bob D.
Of Mark Wonsil
Quantity
Vantage)
triggers
or
a
so
Mark W.
YAHOO! GROUPS LINKS
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
on the web.
_____
Tracking #: 4BC2A626741309429C5B4E206A6660BA289F00F1
We have a few folks here that believe in magic too. And the Great
Pumpkin.
Bob
Of Shirley Graver
Sent: Thursday, October 27, 2005 2:54 PM
Kind
beamed
in.
Shirley
_____
Of
Robert Dillon
Bob D.
Of Mark Wonsil
Quantity
Vantage)
triggers
or
a
so
Mark W.
YAHOO! GROUPS LINKS
have
and
SPONSORED LINKS
Manufacturing
ring
w4=P
ng+s
Membership
ufac
twar
arke
Database
actu
are&
keti
Pda
ing+
4=Pd
g+so
Database
ufac
twar
arke
software
Database
fact
ware
rket
_____
YAHOO! GROUPS LINKS
on the web.
Service
_____
YAHOO! GROUPS LINKS
