We are in 8.0 going soon to 8.03. There's a simular mapping window
in 8.0 but it doesn't include access to the Sales Order tables.
Everything we make resides in the Sales Orders. A large portion
then gets pushed onto jobs through a built-in menu function in Sales
Order Entry, "Order Job Wizard...".
Steven Pybus
Steven Pybus
--- In vantage@yahoogroups.com, "Winter, Patrick" <pjw@...> wrote:
> What version are you on?
> Version 6.1 there is "System Management / Vantage Basic / VB Form
Map"
> which is a program for mapping what you described.
> Patrick Winter
Behalf
> Of Steven Pybus
> Sent: Wednesday, May 09, 2007 1:19 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Copying User-Defined Fields between
> Quote/Order/Job/Parts
> I was interested how much of a problem other users have with this
> situation: When Vantage pushes/pulls data from one area of the
> software to another, it doesn't copy the user defined fields.
> EX: We've set up weight in the quote as QuoteDtl.Number01. When we
> push this into a sales order, the data is left behind and doesn't
> get copied along with all of the canned data. The same problem
> exists when you then push the order to a Job and again when you
use
> GetDetails to bring the info into the PartMaster.
> It seems to me that Vantage should provide a way to configure each
> of these built-in functions: "Create Sales Order...", "Job Order
> Wizard..." to also copy data that's been collected within these
> other areas.
> If all of our parts were in the part master, I could link to there
> and be done but a huge amount of our business is non-repeat that
we
> don't want to clutter up our part master with.
> I had custom programming build me a solution for Quote to Sales
> Order but it seems like this funtionality should be built-in. Am I
> being unreasonable?
> This e-mail and any attachments may contain confidential and
> privileged information. If you are not the intended recipient,
> please notify the sender immediately by return e-mail, delete this
> e-mail and destroy any copies. Any dissemination or use of this
> information by a person other than the intended recipient is
> unauthorized and may be illegal.
