CR Login. Blank Title 66350
If you added your table to the Report Data Definitions in the Company
Maintenance Menu and established your Table Relationship there, then
you do not need to use ODBC or modify your registry.
The instructions are on the Epicor website. Search for AnswerBook #
4778MPS, titled "CR Modifying a Crystal Report form in V8.xx".
The only problem with the instructions in this Answerbook is that in
Section A they neglect to tell you to create the table relationships
for any new tables you add. For any table you add to the Data
Definition, you need to click on the Relationship tab and then click
on the icon for "Add New Relationship" in order to relate the table
you added to the rest of the tables that Epior supplied.
If you follow this Answerbook, you do not need to use ODBC at all.
Therefore, you won't need to install the ODBC drivers and make
registry changes on your users' pcs.
--- In vantage@yahoogroups.com, "Michael McWilliams"
<mmcwilliams22@...> wrote:
> You will do that in the registry. Go to LocalMachine--> Software --
> >ODBC --- ODBC.INI Then choose the database("mfgsys803" or
whatever
> you call it). Create two string keys. One for "UserName" and set
> the value to "sysprogress" and another for password and set the
> value to "sysprogress". If you use a different username or
password
> just replace the values.
> <mmcwilliams22@> wrote:
> > --- In vantage@yahoogroups.com, Bartosz Niemczewski
> > <bartoszniemczewski@> wrote:
> > > I modified POForm which is Purchase Order Report in Vantage
> > 803.405. I add new table in Crystal and attach some fields to
> > report. When I run report from Vantage everything is ok but I
have
> > to put password to login to database. I want to run this report
> > without typing password every time when I run report.
> > > System Agent is setup correctly.
> > > Â
> > > Any Idea?
> > > Â
> > > Thank you.
> > > bArt.
> > > ----- Original Message ----
> > > From: Bartosz Niemczewski <bartoszniemczewski@>
> > > To: vantage@yahoogroups.com
> > > Sent: Monday, June 30, 2008 9:30:28 AM
> > > Subject: Re: [Vantage] CR Login.
> > > this is about Vantage 803.4xx and Open Edge 101B .
> > > thank you.
> > > From: Vic Drecchio <vic.drecchio@ timco.aero>
> > > To: vantage@yahoogroups .com
> > > Cc: bartoszniemczewski@ yahoo.com
> > > Sent: Monday, June 30, 2008 9:13:01 AM
> > > Subject: RE: [Vantage] CR Login.
> > > What version of Vantage and what database (SQL or Progress).
> > > For 8.x Progress, go into your System Agent under System Mgmt --
> > > Utilities. The ODBC connection info is at the bottom.
> > > For SQL, take a look at http://www.connecti onstrings. com/ or
> try
> > these
> > > DRIVER=DataDirect 4.20 32-Bit Progress SQL92
> > > v10.0B;UID=sysprogr ess;PWD=sysprogr ess;HOST= localhost;
> > PORT=8050; DB=mfgsy
> > > s;DIL=READ UNCOMMITTED
> > > DRIVER=DataDirect 4.20 32-BIT OpenEdge SQL
> > PORT=8005; DB=mfgsy
> > > ____________ _________ _________ __
> > > From: vantage@yahoogroups .com [mailto:vantage@
> yahoogroups .com]
> > On Behalf
> > > Of Bartosz Niemczewski
> > > Sent: Monday, June 30, 2008 10:01 AM
> > > To: Vantage Group
> > > Subject: [Vantage] CR Login.
> > > I have report created in Crystal and every time when I run this
> > report I
> > > have to put login and password to access to database and see
> > report.
> > > My question is how to set to run report without typing login and
> > > password every time.
> > > Thank you.
> > > bArt.
I have report created in Crystal and every time when I run this report I have to put login and password to access to database and see report.
My question is how to set to run report without typing login and password every time.
Thank you.
bArt.
For 8.x Progress, go into your System Agent under System Mgmt -->
For SQL, take a look at http://www.connectionstrings.com/ or try these
v10.0B;UID=sysprogress;PWD=sysprogress;HOST=localhost;PORT=8050;DB=mfgsy
v10.0B;UID=sysprogress;PWD=sysprogress;HOST=localhost;PORT=8005;DB=mfgsy
To: Vantage Group
Thank you.
bArt.
thank you.
Cc: bartoszniemczewski@...
For SQL, take a look at http://www.connecti onstrings. com/ or try these
v10.0B;UID=sysprogr ess;PWD=sysprogr ess;HOST= localhost; PORT=8050; DB=mfgsy
v10.0B;UID=sysprogr ess;PWD=sysprogr ess;HOST= localhost; PORT=8005; DB=mfgsy
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
To: Vantage Group
Thank you.
bArt.
I modified POForm which is Purchase Order Report in Vantage 803.405. I add new table in Crystal and attach some fields to report. When I run report from Vantage everything is ok but I have to put password to login to database. I want to run this report without typing password every time when I run report.
Â
Any Idea?
Â
Thank you.
bArt.
thank you.
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
To: Vantage Group
Thank you.
bArt.
>ODBC --- ODBC.INI Then choose the database("mfgsys803" or whatever
value to "sysprogress". If you use a different username or password
> > Â
> > Any Idea?
> > Â
> > Thank you.
> > bArt.
> > thank you.
try
> these
> PORT=8050; DB=mfgsy
> PORT=8005; DB=mfgsy
yahoogroups .com]
> On Behalf
> > To: Vantage Group
> report I
> report.
> > Thank you.
> > bArt.
