Crashing and also how to trace/debug
Hello, we are in pre-implementation phase and doing testing (in Test environment).
We recently upgraded to 10.2.400.2 and I am crashing pretty regularly when opening the Method Tracker from the Part screen.
First of all, is this a known issue? Anyone else experiencing this?
Second, what is the procedure for troubleshooting something like this? Like is there a procedure for debugging using traces or log files? Any documentation on this? I looked in the help contents and couldn’t find anything there.
I remember a session at Insights where they talked all about troubleshooting but my notes aren’t that good.
We have logged a support request but no answers yet. Any help is appreciated.
A couple of basics that I would always check when troubleshooting an issue with screen opening/crashing:
  1. Clear Client Cache
  2. Remove Personalisations on that screen
  3. Login as another user on the same PC - is it user specific issue?
  4. Login as same user, on a different PC - does the problem follow the user?
  5. Reinstall Client
I will try those - thanks!
OK it was a personalization. I deleted them and no more crashing. :smiley:
First I deleted the cache, and no change but deleting the personalization worked.
thanks
Excellent - you can hit the Solved button on my post if that was what solved it :slight_smile:
