Crystal Reports 8.5 compiled reports not exporting to Excel
I do think Gary was probably thinking of me. I have been talking to
Epicor about this, and they sent me a "sort of related" document
which suggested comparing the workstation and Vantage server dll
files -- p2bxbse.dll and msvcp60.dll. The versions were out of
whack, so I copied the server versions to my workstation, as the
document suggested, but it did not help. One of the techs at Epicor
is working with one of my reports to try to find a solution.
I always flag the DLL's for exporting.
What about Windows hot fixes? Could that be a source of problems
with the dll's?
--- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@...> wrote:
> Liz
> I cannot remember to hand, but it might be worth checking all the
dll's
> especially the ones beginning with cr
> When you distributed your reports did you flag 'DLL's for
exporting'
> Gary
Behalf
> Of Elizabeth Hahn
> Sent: 06 February 2007 21:29
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Crystal Reports 8.5 compiled reports not
> exporting to Excel
> Hi Gary,
> Do you have the exact name of the DLL? I looked, but I didn't
unless
> it's abbreviated funny.
> Liz
> -----Original Message-----
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ]On
> Behalf Of Gary Parfrey
> Sent: Tuesday, February 06, 2007 12:41 PM
> exporting to Excel
> Liz
> Make sure you have the crystal excel export dll in the system32
> directory and it is the same version as the workstation that works
> Gary
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto: vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com] On
> Behalf
> Of tlp2120
> Sent: 06 February 2007 14:32
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] Re: Crystal Reports 8.5 compiled reports not
> exporting to Excel
> Liz:
> I've had that problem since Day One here, and just try to slog
> through it. Even my predecessor warned me and was never able to
> solve it. I've tried all your suggestions over the past two years.
> I've also tried exporting to different versions of Excel.
Sometimes
> it works, sometimes it doesn't. But that's on reports that I've
> either already successfully compiled, or reports I'm just running
> straight from the Crystal application.
> This new problem is that I can't even compile reports so they can
be
> run across others varying systems, and I know that it's because I
> myself have a new system. I can compile reports for use on ONE
> guy's system so far. I just don't know the difference - yet.
> Anyway ,boy, did I appreciate your response! Nobody here believes
> me. They all think it's just me. It's good to hear I'm not alone.
> I'll keep at it. And I'll let you know if I ever fix the first
> aggravation.
> Thanks for the validation,
> Theresa
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> <mailto:vantage%40yahoogroups.com> ,
> "Elizabeth Hahn" <ehahn@> wrote:
> > Hi Theresa,
> > I have had similar issues too. The strange thing is that it
isn't
> consistent, some days I can export without a problem, other days
> not. One thing that does work for me is to export to a .CSV file
> and then convert that to excel. The error messages I get are
> different though, I get a message that says "crystal reports has
> encountered a problem and needs to close. We are sorry for the
> inconvenience...."
> > Some things I've tried that sometimes seem to help:
> > 1. Refresh data, save report, close Crystal. Restart Crystal,
> open report, but don't refresh, and then export.
> > 2. Conversely, don't save data with report, close crystal,
> restart crystal then export.
> > 3. Remove/hide header and footer, and tab stops at the top and
> sides of the report
> > I also am running these on my own PC with Crystal 8.5 2.718.
> > If you find a solution please let me know, it might help my
> problem too!
> > Thanks,
> > Liz
> <mailto:vantage%40yahoogroups.com> ]On
> Behalf Of tlp2120
> > Sent: Friday, February 02, 2007 12:58 PM
> > Subject: [Vantage] Crystal Reports 8.5 compiled reports not
> exporting to Excel
> > Hi all,
> > I'm having problems compiling Crystal Reports to my users'
> > workstations, as well as having performance problems running
> > compiled reports myself. The background is that:
> > * We're on Vantage 6.1
> > * Using Crystal Report 8.5 with the Report Distribution Expert.
> > * Our company has been slowly replacing PC's, and mine was
> replaced
> > in mid-December. My PC has Windows XP Professional.
> > * I'm trying to compile reports for older and newer workstations.
> > When I compile a report and test it at my own workstation, I am
> able
> > to print to a window, export to Excel from the window (in some
> > cases, and in some cases not). I cannot export from the opening
> > dialog box -- I get an error saying "Print Engine Error: Error
in
> > File C:\Program Files\Seagate Software\Distributed Reports\PAP
> Sales
> > Report-compile test.rpt: Parameter has invalid structure size."
In
> > SOME cases, this same error appears without the report even
> > running. In OTHER cases, these reports CAN export from the
opening
> > dialog box on older PC's.
> > On one of the new PC's, trying to export to excel from
the "print
> > preview" window, produces this error, "An unhandled win32
> exception
> > occurred in crrun32.exe [2372]."
> > I have screen shots of the errors if anyone wants to see them,
but
> I
> > was unable to attach any here.
> > Epicor has been unable so far to come up with the solution, but
> they
> > believe it has to do with the .dll's.
> > Has anyone had this happen, or have any suggestions? (And PLEASE
> > feel free to ask for clarification.)
> > Thanks,
> > Theresa Pancoast
> > FS-Elliott Co., LLC
Hi all,
* Our company has been slowly replacing PC's, and mine was replaced
When I compile a report and test it at my own workstation, I am able
dialog box -- I get an error saying "Print Engine Error: Error in
File C:\Program Files\Seagate Software\Distributed Reports\PAP Sales
Report-compile test.rpt: Parameter has invalid structure size." In
running. In OTHER cases, these reports CAN export from the opening
On one of the new PC's, trying to export to excel from the "print
preview" window, produces this error, "An unhandled win32 exception
I have screen shots of the errors if anyone wants to see them, but I
Epicor has been unable so far to come up with the solution, but they
Theresa Pancoast
FS-Elliott Co., LLC
Hi Theresa,
I have had similar issues too. The strange thing is that it isn't consistent, some days I can export without a problem, other days not. One thing that does work for me is to export to a .CSV file and then convert that to excel. The error messages I get are different though, I get a message that says "crystal reports has encountered a problem and needs to close. We are sorry for the inconvenience...."
1. Refresh data, save report, close Crystal. Restart Crystal, open report, but don't refresh, and then export.
2. Conversely, don't save data with report, close crystal, restart crystal then export.
3. Remove/hide header and footer, and tab stops at the top and sides of the report
If you find a solution please let me know, it might help my problem too!
Liz
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of tlp2120
Subject: [Vantage] Crystal Reports 8.5 compiled reports not exporting to Excel
Hi all,
Theresa Pancoast
FS-Elliott Co., LLC
Liz:
I've also tried exporting to different versions of Excel. Sometimes
This new problem is that I can't even compile reports so they can be
aggravation.
Theresa
--- In vantage@yahoogroups.com, "Elizabeth Hahn" <ehahn@...> wrote:
> Hi Theresa,
inconvenience...."
sides of the report
problem too!
> Thanks,
> Liz
Behalf Of tlp2120
exporting to Excel
> Hi all,
replaced
able
Sales
exception
I
they
> Thanks,
> Theresa Pancoast
> FS-Elliott Co., LLC
Liz
Gary
Of tlp2120
exporting to Excel
Liz:
aggravation.
Theresa
> Hi Theresa,
inconvenience...."
sides of the report
problem too!
> Thanks,
> Liz
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of tlp2120
exporting to Excel
> Hi all,
replaced
able
Sales
exception
I
they
> Thanks,
> Theresa Pancoast
> FS-Elliott Co., LLC
Hi Gary,
Do you have the exact name of the DLL? I looked, but I didn't unless it's abbreviated funny.
Liz
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Gary Parfrey
Subject: RE: [Vantage] Re: Crystal Reports 8.5 compiled reports not exporting to Excel
Liz
Gary
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of tlp2120
exporting to Excel
Liz:
aggravation.
Theresa
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com> ,
> Hi Theresa,
inconvenience...."
sides of the report
problem too!
> Thanks,
> Liz
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of tlp2120
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
exporting to Excel
> Hi all,
replaced
able
Sales
exception
I
they
> Thanks,
> Theresa Pancoast
> FS-Elliott Co., LLC
Liz
I cannot remember to hand, but it might be worth checking all the dll's
When you distributed your reports did you flag 'DLL's for exporting'
Gary
Of Elizabeth Hahn
exporting to Excel
Hi Gary,
Liz
exporting to Excel
Liz
Gary
Behalf
Of tlp2120
exporting to Excel
Liz:
aggravation.
Theresa
> Hi Theresa,
inconvenience...."
sides of the report
problem too!
> Thanks,
> Liz
Behalf Of tlp2120
exporting to Excel
> Hi all,
replaced
able
Sales
exception
I
they
> Thanks,
> Theresa Pancoast
> FS-Elliott Co., LLC
I haven't actually tried distributing these. We have had a lot of problems getting that to work. I'm getting the problem on my own machine with Crystal installed on it.
(or were you thinking of Theresa on the second sentence?)
Liz
Sent: Tuesday, February 06, 2007 02:59 PM
Liz
Gary
Of Elizabeth Hahn
exporting to Excel
Hi Gary,
Liz
exporting to Excel
Liz
Gary
Behalf
Of tlp2120
exporting to Excel
Liz:
aggravation.
Theresa
> Hi Theresa,
inconvenience...."
sides of the report
problem too!
> Thanks,
> Liz
Behalf Of tlp2120
exporting to Excel
> Hi all,
replaced
able
Sales
exception
I
they
> Thanks,
> Theresa Pancoast
> FS-Elliott Co., LLC
