Crystal reports version conflict - Ideas?
I had the same thing happen. User who print crystal report forms out of
vantage were wondering what happened to
the data. Turned out that ABRA ships the V7 CR service patch at level 1.
All of my Vantage CR reports have been
processed with patch 2. I spoke to Best tech support and they suggested
installing ABRA first, and then vantage
(to write over the dll that is causing the problem) I am in the process of
doing this. In the mean-time, I had to uninstall
ABRA from those users that are print crystal reports out of Vantage.
Uninstalling ABRA fixed the problems on the
clients.
_____
Sent: Wednesday, November 19, 2003 11:48 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Crystal reports version conflict - Ideas?
"falling behind in Vantage
upgrades"
That would be one way of putting it ... :-)
Sent: Wednesday, November 19, 2003 10:31 AM
You have a user who is printing Abra reports (CR 8.5) and Vantage AP checks
(CR 7) from the same PC?
Separate PC's may have to be used since your falling behind in Vantage
upagrades.
I don't think uninstalling Crystal will remove everything.
You might try contacting Crystal Reports to see what they say.
Also Abra includes crystal with the product but I don't think it's exactly
the save Crystal you buy off the shelf.
Patrick Winter
Sent: Wednesday, November 19, 2003 10:12 AM
Subject: [Vantage] Crystal reports version conflict - Ideas?
Ok, I'm stumped - any ideas?
* Vantage V4 / Crystal V 7
* Installed BEST Abra upgrade which uses Crystal V 8.5
* Vantage AP Checks no longer print correctly - 1st check ok - all other
checks the top of the form is missing all detail and totals.
--- tried resetting CRPE32.DLL on the PC in question back to the old version
- no luck
--- tried uninstalling Crystal V 8.5 to see if the checks would revert to
old form - no luck
--- tried re-installing Vantage client - no luck
Ideas?
Todd Anderson
------------------------ Yahoo! Groups Sponsor ---------------------~--> Buy
Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark Printer
at MyInks.com. Free s/h on orders $50 or more to the US & Canada.
http://www.c1tracking.com/l.asp?cid=5511
<http://www.c1tracking.com/l.asp?cid=5511>
<http://www.c1tracking.com/l.asp?cid=5511> >
http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/PhFolB/TM
<http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/PhFolB/TM>
<http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/PhFolB/TM> >
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
<http://docs.yahoo.com/info/terms/>
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12ct822st/M=243273.4156324.5364586.1261774/D=egroup
web/S=1705007183:HM/EXP=1069345859/A=1750744/R=0/*http://servedby.advertisin
<http://servedby.advertisin>
g.com/click/site=552006/bnum=1069259459147548> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmai
l/S=:HM/A=1750744/rand=500328884>
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cqpgupo/M=267637.4116730.5333196.1261774/D=egroup
web/S=1705007183:HM/EXP=1069346881/A=1853618/R=0/*http://www.netflix.com/Def
ault?mqso=60178338&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmai
l/S=:HM/A=1853618/rand=729715507>
- no luck
old form - no luck
Ideas?
Todd Anderson
Todd,
Uninstalling Crystal 8.5 may not have removed all the newer dll's. I had to
manually delete some when I reverted back to 8.0 from 8.5.
Dan Shallbetter
States Electric Mfg.
- no luck
old form - no luck
Ideas?
Todd Anderson
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c776pq2/M=267637.4116719.5338353.1261774/D=egroup
web/S=1705007183:HM/EXP=1069344714/A=1853619/R=0/*http://www.netflix.com/Def
ault?mqso=60178356&partid=4116719>
<http://us.adserver.yahoo.com/l?M=267637.4116719.5338353.1261774/D=egroupmai
l/S=:HM/A=1853619/rand=241552719>
I sort of had this when I tried to go from 8 to 8.5 then wanted to go back to 8. The uninstall does not remove a bunch of DLLs. I had to do a registry hack too to clean out references to 8.5. It took a good week or struggling to remove 8.5 completely. I'll check old list messages because I think I had a list of steps posted here once.
-Todd C.
- no luck
old form - no luck
Ideas?
Todd Anderson
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c776pq2/M=267637.4116719.5338353.1261774/D=egroupweb/S=1705007183:HM/EXP=1069344714/A=1853619/R=0/*http://www.netflix.com/Default?mqso=60178356&partid=4116719> click here
<http://us.adserver.yahoo.com/l?M=267637.4116719.5338353.1261774/D=egroupmail/S=:HM/A=1853619/rand=241552719>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
upagrades.
Patrick Winter
- no luck
old form - no luck
Ideas?
Todd Anderson
upgrades"
upagrades.
Patrick Winter
- no luck
old form - no luck
Ideas?
Todd Anderson
ADVERTISEMENT
