In 8.00.xxx the task works if you first perform an export to get the
headers on the spreadsheet. I have a "unofficial procedure" that I
wrote up for 8.00, might work the same in V6.....If you want me to e-
mail you a copy drop me a line at rcarlson@..., subject =
Cust/Contact Import/Export.
Regards, Bob C.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...>
Regards, Bob C.
wrote:
>in the
> > I'm on Vantage version 6.10.535.
> > I'm having trouble using the Customer / Contact Import function
> > CRM module and Epicor Technical support told me they're havingthe same
> > problem and will get back to me once they figure it out.IS NOT
> > Have any of you had to deal with this and solved it?
> > The error I'm getting is "THE FORMAT OF THE CUSTOMER IMPORT FILE
> > CORRECT."specified in
> > I've formatted it exactly according to the CSV file details
> > the help program, but to no avail.specification? That
> > Is the required format different from the help file
> > would not be a first.NOT explain
> In 8.0, we found that the format was correct but the help file did
> which fields were mandatory. It's been awhile but I believe thatyou *must*
> pass in a custID and a country. As a trial, fill out a record withevery field
> filled and try loading it and see if you still get the error.(Also check to
> make sure that your data does not include any commas...)
> Mark W.
