glad it helped you…makes writing it up worth while!
@tonyb1986 @hmwillett
it is great effort and excellent document so thank you Tony & Hannah, but is it missing the trigger as i am following it step by step with no luck ???
hmmmm the trigger to populate is from step 9…however epicor LOVE changing things so there may be a different tweak to this now, ours is still functioning since i added it using this method, i will give it a try in Education tomorrow and see if there is anything i spot different (not promising i can help as i still consider myself a newbie but i will certainly try to help!)
