I’m getting this error while working on a dashboard. Any ideas?
Application Error
Error Detail
Message: WC-ShipmentsPerCustomer-By Order: View Filter exception. View Filter not applied. A DataColumn has been dropped from BAQ results table.
Inner Exception Message: Cannot perform ‘=’ operation on System.Int32 and System.String.
Program:
Method:
Inner Exception
Inner Stack Trace
at System.Data.BinaryNode.BinaryCompare(Object vLeft, Object vRight, StorageType resultType, Int32 op, CompareInfo comparer)
at System.Data.BinaryNode.EvalBinaryOp(Int32 op, ExpressionNode left, ExpressionNode right, DataRow row, DataRowVersion version, Int32[] recordNos)
at System.Data.BinaryNode.Eval(DataRow row, DataRowVersion version)
at System.Data.DataExpression.Invoke(DataRow row, DataRowVersion version)
at System.Data.Index.AcceptRecord(Int32 record, IFilter filter)
at System.Data.Index.InitRecords(IFilter filter)
at System.Data.Index…ctor(DataTable table, IndexField[] indexFields, Comparison`1 comparison, DataViewRowState recordStates, IFilter rowFilter)
at System.Data.DataTable.GetIndex(IndexField[] indexDesc, DataViewRowState recordStates, IFilter rowFilter)
at System.Data.DataView.UpdateIndex(Boolean force, Boolean fireEvent)
at System.Data.DataView.UpdateIndex(Boolean force)
at System.Data.DataView.SetIndex2(String newSort, DataViewRowState newRowStates, IFilter newRowFilter, Boolean fireEvent)
at System.Data.DataView.SetIndex(String newSort, DataViewRowState newRowStates, IFilter newRowFilter)
at System.Data.DataView.set_RowFilter(String value)
at Ice.UI.Dashboard.DashboardView.ApplyViewFilter(IPublisher pub, PublishEventArgs args)
