DMT and Inventory Transfer
Found the problem... right at my own doorstep.
I had uploaded a number of Inventory Transfers via DMT on 2/1, but it turns out that the file I uploaded was at least 2 weeks old, so naturally inventory levels had changed. Epicor will allow the DMT to bring a bin to a negative stock level even if the Part Class that part belongs to has a "Stop" flag, and that once a part actually GOES negative it can stay negative and move all around.
Now to fix the issues with as little further harm as possible...
Ernie Lowell
Diba Industries
--- In vantage@yahoogroups.com, "Elizabeth" wrote:
> Running 6430 had no effect.
> My testing so far indicates (with "Stop" set at the Part Class level) that when a part is already has a negative QOH, it will allow it to stay negative (it can change from -50 to -30 OR to -80 OR to +50)... but if a part has a positive QOH, it will not allow it to go negative (can go from +50 to +30 OR +80 BUT NOT -1).
> I have to step through PartTran more closely to see exactly what happened. This is affecting at least 50 part numbers.
> My controller was out yesterday and I can't WAIT to spring this on him today!
> Thanks again,
> Ernie Lowell
> Diba Industries
> --- In vantage@yahoogroups.com, Stephen Edginton wrote:
> > Ernie,
> > Please run conversion 6430 then try again
> > If you still have issues
> > Verify if you caused the parts to go negative with the STK-STK transactions?
> > Next
> > Confirm with a new part if the part class negative handling is working or not.
> > Finally
> > If this still doesn't correctly escalate to technical solutions group at Epicor and someone will investigate for you.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Elizabeth
> > Sent: 12 February 2013 21:06
> > Subject: [Vantage] DMT and Inventory Transfer
> > 9.04.507A SQL
> > Ran a DMT session (2 weeks ago, just finding all these things out now) to move some parts around into different bin locations, and now some issues:
> > Several Part Classes that have a "Stop" on negative inventory are not Stopping anymore.
> > Several part numbers are showing negative quantities in the bins FROM which I transferred them, even though that bin is no longer the Primary Bin as defined in Part > Plants > Warehouses.
> > Part Transaction History shows the CORRECT STK-STK transactions.
> > PartWhse.OnHandQty is the same as the sum of PartBin.OnHandQty for each part number (we only have one warehouse, but several parts are in multiple bins, moreso now).
> > A little lost, any ideas?
> > Ernie Lowell
> > Diba Industries
9.04.507A SQL
Ernie Lowell
Diba Industries
Ernie,
Next
Finally
9.04.507A SQL
Ernie Lowell
Diba Industries
Stephen,
Thanks for the reply. I had thought that since PartWhse and the sum of the PartBins were equal, 6430 would not help, but I didn't try it... it's running now. We had a big problem with that a year or so ago, and I created a report to tip me off (I still run it before month-end just to keep my controller happy, but it hasn't been off for quite some time).
I'll let you know how it turns out.
Ernie Lowell
Diba Industries
> Ernie,
> Next
> Finally
> 9.04.507A SQL
> Ernie Lowell
> Diba Industries
Thanks again,
Ernie Lowell
Diba Industries
> Ernie,
> Next
> Finally
> 9.04.507A SQL
> Ernie Lowell
> Diba Industries
