E10.1.400.21 PO Suggestions Hangs on Regen
Just ran upgrade for Test DB to 10.1.400.21
Ran PO Suggestions for Full Regen and it hangs on deleting suggestions
The Suggestion log file is returning this error
An unsecured or incorrectly secured fault was received from the other party. See the inner FaultException for the fault code and detail.
SugPODtl table returns no records
Hi,
I knew this is pretty old thread to recall. However, I too getting this type of message in my MRP log. I just want to recall this issue and let me know the resolution of this issue in your case.
“An unsecured or incorrectly secured fault was received from the other party. See the inner FaultException for the fault code and detail”
We restored the database from Prod to Dev, and we had the same error message.
After the restore we needed to modify the System Agent to point to the Dev environment.
The error appeared after the changes.
To fix it, we just restarted the Task Agent.
Epicor version 10.2.100.33
