These are directions given to by Tim Berryman
A large number of images can still prevent Epicor/Vantage from printing the report no matter the file type.
To resolve the issue create a small blank jpeg file (e.g. 150 px by 150 px) and put it in the position you need the final image to reside.
Then Right Click the image > Format Graphic > Picture 'tab' > Click the code icon next to Graphic Location > Enter the following text > "filepath\filename"
When crystal compiles the report it will replace the blank image with the one specified. This helps keep the crystal file size to a minimum and Epicor/Vantage allows you to print the report.
This should resolve your issues.
I forgot to mention that it's a good item to create athe image you are putting into the report at the exact size that is required in the report. This will avoid unnecessary problems with large and small images.
This reduced a report with a footprint of 2700kb to 119kb.
Verl Romrell
Lattice Materials LLC
Verl Romrell
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> How did you do that?
> From: vwildthingr <wildthing@...>
> To: vantage@yahoogroups.com
> Sent: Thu, 28 October, 2010 14:47:04
> Subject: [Vantage] Re: E9: Custom Crystal reports cause "Out of Memory"
> ÂÂ
> Motty,
> We had a similar problem in epicor 9.
> Our solution was to create an image place holder in the report and then pull the
> image into the report from a file in a folder on the server.
> This allowed us to use larger images with better resolution and still keep the
> report footprint down to minimum.
> Verl Romrell
> verlr@...
> --- In vantage@yahoogroups.com, "mseal" <mseal@> wrote:
> > so, we too are having similar issues with out of memory â€" we already reduce
> >size to around 2Mb and get the error every so often.
> > Regarding the purge of reports â€" I'm on 600C and it does not seem to be purging
> >â€" is there something I'm missing â€" on 8 it was not an issue.
> > Also found that cashed files into the EpicorData directory do not purge and I
> >manage to fill up a 25Gb drive in less than a day if I don't run a batch job to
> >clean them up â€" any thoughts?
> > Thanks
> > Motty
> > --- In vantage@yahoogroups.com, "doily2oo5" <doily2oo5@> wrote:
> > > That was precisely the problem! Our logo was large (only 2MB but should have
> >been handled easily by the system) and by downsizing it have not run into the
> >problem since. Thank you, Chris, for the insight! That's what this group is all
> >about.
> > > Mike
> > > --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > > > Do your rpt files containt large images?
> > > > We had an issue when we switched from v8 to e9 where v8 could handle much
> >larger .rpt files that e9 can. Reports would work every time in v8 but when we
> >tried them in e9, 50% of the time we would get this out of memory problem.
> > > > Touch wood, since shrinking the images sizes, it hasnt happened as much but
> >occasionally still does.
> > > > If its happening with the canned reports, I dont know what to suggest.
> > > > On a slightly different note, you know how you can set your archive period
> >of your reports when you print them? Have you noticed how 0 Days and 1 Month are
> >exactly the same thing?
> > > > 0 Days doesnt actually mean that they are only archived for a short time.
> >They are actually archived for 30 days.
> > > > ÂÂÂ
> > > > From: doily2oo5 <doily2oo5@>
> > > > Sent: Thu, 4 February, 2010 15:22:15
> > > > Subject: [Vantage] E9: Custom Crystal reports cause "Out of Memory"
> > > > ÂÂÂ
> > > > We are experiencing the following message several times through the course
> >of the day when generating custom SO Acknowledgement or Quote Crystal reports
> >that causes us to restart Epicor. We haven't gotten it with canned reports and
> >the customized reports look good. Of significance is that we use two separate UD
> >tables from which we retrieve part specifications. We have checked for spikes in
> >memory use at the server and at the workstations (this happens at all
> >workstations that generate the reports)with nothing anomalous. We have noticed
> >that Epicor housekeeping of .tmp files is non-existent and that they reside
> >during and after report generation. Any insights would be helpful. Trouble call
> >has been submitted to Epicor.
> > > > Error Detail
> > > > Exception of type 'System.OutOfMemory Exception' was thrown.
> > > > Stack Trace
> > > > at System.String. Concat( String str0, String str1 )
> > > > at Epicor.Mfg.BO. ReportMonitor. transferReportDe finition( String
> >sysRowID, String definitionPath
> > > > at Epicor.Mfg.BO. ReportMonitor. TransferReport( String sysRowID, String
> >dataPath, String
> > > > definitionPath )
> > > > at Epicor.Mfg.UI. Adapters. ReportMonitorAda pter.TransferRep ort( String
> >sysRowID, String
> > > > fileNameData, String fileNameRepDef )
> > > > Thank you.
> > > > Mike Doyle
> > > > 406-556-5759
> > > > [Non-text portions of this message have been removed]
> Reply to sender | Reply to group | Reply via web post | Start a New Topic
> Messages in this topic (6)
> Recent Activity: * New Members 1 * New Photos 2
> Visit Your Group
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/files/.%c3%82%c2%a0
> MARKETPLACE
> Get great advice about dogs and cats. Visit the Dog & Cat Answers Center.
> Hobbies & Activities Zone: Find others who share your passions! Explore new
> interests.
> Stay on top of your group activity without leaving the page you're on - Get the
> Yahoo! Toolbar now.
> Switch to: Text-Only, Daily Digest • Unsubscribe • Terms of Use
