Enterprise Search 10.1 - rebuild and context menu
I’m implementing Enterprise Search in 10.1.600 and had a couple questions - hoping someone can help:
  1. Is there a way to change the default link to open with a tracker instead of an entry screen?
  2. Does the scheduled rebuild process only do a net change? (I remember in 9.05.702 there was a date stamp ES used, couldn’t find documentation on the 10.1 rebuild on this).
Thanks!
Jenn
Hi Jenn,wondering if you able to find out this in the end?
This uses the Context Menu (right click Open With menu). You can change what the form is opened by editing this. Remember, you have to click the Customize checkbox if you want the change to affect everyone.
We just told everyone they should right-click open with the trackers because they have more information. I might give John’s answer a look when I get some extra time - won’t be for a while yet though.
Good luck Sandy!
Jenn
Thank you JennL~~
Thank you John, will look into thosemany thanks
