That's correct. The factor is completely ignored and only the UM is used. We decided to convert everything to EA except the obvious like Ft, In, Yd, Oz etc. Packages, Bags, Reels, Rolls are all converted to Ea. Future PO's may need these entered with the appropriate factor.
We've left it up to our Purchasing and Engineering Managers how to set up the UM Classes and UM's. Sometimes they specify a UM conversion in a line comment. But the Open PO's at time of conversion should be checked.
--- In vantage@yahoogroups.com, "Kunze, Kim" <kkunze@...> wrote:
> We have tens of thousands of parts that have factors converting from our
> inventory UOM of EA to a purchasing UOM of LB. I have been told by our
> IT folks that the conversion program that they are using to convert our
> v8 data to Epicor 9 data is not smart enough to take the existing
> factors on our parts and create Epicor 9 parts with the new UOM class
> arrangement.
> Anyone else encounter that issue and if so what did you do other than to
> manually enter each part's factor?
> Kim A Kunze
> Lean Six Sigma Black Belt
> Wausau Window and Wall Systems
> 715-846-3244
