Agreed on the "slower on some things". I didn't get a chance to put the two major suggestions (namely the "enablelargefiles" and the -1 parameter) into action until 9:30pm last night. I kicked off the conversion and went to bed. This morning at 5:15 it was still clunking away doing something with tax updates? Whatever.
Â
Thanks for all the suggestions.
-Karl
Â
-Karl
--- On Wed, 7/8/09, DD <ddavis4569@...> wrote:
Subject: Re: [Vantage] Epicor 904.503B Home PC
Date: Wednesday, July 8, 2009, 4:38 AM
It also solves the issue of having to increase the locks. Big issue in converting to 9.04.
Some things are faster in single user mode as it is not having to do the locking but other things are slower due to the buffering and multi tasking of multi user mode.
To: vantage@yahoogroups .com
Date: Tuesday, July 7, 2009, 4:47 PM
Ok, thanks for the tip. I don't believe I have seen the option of the -1 for single user mode before. Good to know.
Â
-Karl
Date: Tuesday, July 7, 2009, 1:30 PM
I installed 9.04 on a OLD laptop with only 1 gig of ram to see if it would work.
It installed and converted the database.
It was a little slow on the conversions at times but I did them in single user mode which would save on all the data locking.
Â
Just make a shortcut of the Vantage 9.04 Schema Change and edit the properties.
Add a -1 after the prowin32.exe to start it in single user mode.
The database is not started. It is not running during the conversion.
(This also fixes the bug that some people are getting with the license where the CRC does not match before the conversion and the license file can not be loaded before the conversion)
Â
Â
I used it for a couple weeks like that before I installed on the 8.03 server.
Â
--- On Mon, 7/6/09, Karl Dash <dashkarl@yahoo. com> wrote:
Subject: [Vantage] Epicor 904.503B Home PC
To: "Vantage Group" <vantage@yahoogroup s .com>
Date: Monday, July 6, 2009, 6:05 PM
Â
I'm trying to install 904.503B on my home PC (I'm a glutton for punishment, sue me). I have gotten as far as step 10.8 (Data Conversions) and well into the conversions ... it's running program cvg10014.p Update GLAccount on GLJrnDtl, when it spits out the error "SYSTEM ERROR: Unable to extend database within Schema Area. (8897)". Clicking OK on that gives up another message: "User XX died with 3 buffers locked (5027)".
Â
The database closes, the main appserver closes and the database will not restart to ACTIVE. This PC has only 2GB of memory, could that be part of the problem or is there another parameter that can be tweaked to get beyond this step?
Â
-Karl
