Epicor docstar - Relocation of SQL Database on site
Hi
I’m planning on moving the docstar sql database to a different server.
Has anyone done this in the past? Is it just a case of, once the DB is moved to the new server changing the reference in the Eclipse server SQL Management screen? the DB itself will not change, just the hosted server.
I did ask Epicor support for their knowledge…but they had none. None at all! and wanted me to pay professional services to do it for me! on top of a rather large support contract. Grrrr
Yes, move all 3 databases - AAAA0001, Astria_Host, Backplane. Repoint in Eclipse Management and also inside of ECM.
AstriaHost.dbo.CompanyInstance must be changed with a direct sql update. You have to change it to the new server name or else all of your documents will actually be stored on your old server for the past 4 years and you’ll have no idea until you shut that server off and then you can’t log into ECM and you’ll have to spend weeks with ECM Development (who are awesome by the way) to create a bunch of custom scripts to migrate all of your data. Ask me how I know.
Put in a ticket in Epiccare for the Company instance update code.
Nice one, Thanks. I’ve give this a go in a week or so. I see the field that you were talking about, That’s fine on the update I can do that. Thanks again, it sounded like a real drag for you! You would think they could provide documentation on this! Mind you they don’t even have documentation on how to install an update.
