Epicor running on Solid State hard drives
Thank you,
The most time consuming process for us is "Job Receipts to Inventory".
We even changed the client PC where they do the transactions, nothing
changed. It takes me a while to test it on my PC connected to a totally
different switch, so it's not the network either.
Mike Tonoyan / Natel Engr.
mtonoyan@...
Of Waffqle
Sent: Tuesday, August 16, 2011 10:54 AM
Subject: Re: [Vantage] Epicor running on Solid State hard drives
The difference is massive. The amount of improvement will vary between
activities. That said, even our slowest processes are doubled in speed.
I'd
recommend them wholeheartedly.
However, if you haven't done so already, I'd suggest looking at your
client
performance in comparison to your server performance. If your clients
are
bogged down, improving the server will make little difference.
On Tue, Aug 16, 2011 at 1:11 PM, Steven Gotschall
<sgotschall@...>wrote:
> We switched to a new server this year that had solid state drives on a
RAID
> 10 configuration. Even with only 4 solid state drives, it made a big
> difference.
> From: Mike Tonoyan <mtonoyan@...>
> Sent: Tuesday, August 16, 2011 12:44 PM
> Subject: [Vantage] Epicor running on Solid State hard drives
> I was wondering if anyone has switched from hard drives to solid state
> drives running Epicor and how it affects the performance. I downloaded
> and read "Epicor Solid State Drive hardware guide". It sounds great in
> theory but will be nice to hear from the users.
> mtonoyan@...
> __________________________________________________________
> Notice: This email transmission may contain confidential information
and is
> intended only for the person(s) named. Any use, copying or disclosure
to/by
> any other person(s) is strictly prohibited. By accepting this
information,
> recipients confirm that they understand and will comply with all
applicable
> ITAR and EAR requirements.
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
______________________________________________________________________
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
I figured I would throw this out here to see how you would tackle this issue.
I've got roughly 2000 Parts that need to have the same 3 or 4 materials in varying quantities added to their BOMs.
I'm thinking I have the option of either doing it by hand or developing a Service Connect workflow. Neither of those options are very appealing to me but I figured I'd ask how you would tackle the problem if assigned to you.
We're a 64-bit Progress 9.05.603 environment.
Thanks in advance,
SB
I would use the DMT tool myself.
mtonoyan@...
Of sbraudrick@...
Sent: Monday, August 15, 2011 3:54 PM
Subject: [Vantage] Mass Add Materials to multiple BOMs
issue.
to you.
Thanks in advance,
SB
DMT or service connect is probably the right answer, but you might get away with a scripting utility like autohotkey.
Received: Monday, 15 Aug 2011, 7:57pm
To: vantage@yahoogroups.com [vantage@yahoogroups.com]
Subject: RE: [Vantage] Mass Add Materials to multiple BOMs
mtonoyan@...<mailto:mtonoyan%40natelengr.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of sbraudrick@...<mailto:sbraudrick%40ymail.com>
issue.
to you.
Thanks in advance,
SB
mtonoyan@...
We switched to a new server this year that had solid state drives on a RAID 10 configuration. Even with only 4 solid state drives, it made a big difference.
Â
mtonoyan@...
activities. That said, even our slowest processes are doubled in speed. I'd
However, if you haven't done so already, I'd suggest looking at your client
performance in comparison to your server performance. If your clients are
> difference.
> mtonoyan@...
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Are you running 2 physical servers? We are wondering if the performance
increase is on the app server or the sql server.
On Tue, 16 Aug 2011 13:53:55 -0400
vary between
your clients are
difference.
>it made a big
> difference.
>drives
>to solid state
>I downloaded
>sounds great in
> mtonoyan@...
>information and is
>or disclosure to/by
>this information,
>with all applicable
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Note: You must have already linked your email address to
Report Builder and Crystal Reports and other 'goodies',
please goto: http://groups.yahoo.com/group/vantage/files/.
services goto:
Links
We run all of your Epicor stuff on 1 VM. But we're only supporting about 50
users.
> vary between
> your clients are
> difference.
> >it made a big
> > difference.
> >drives
> >to solid state
> >I downloaded
> >sounds great in
> > mtonoyan@...
> >information and is
> >or disclosure to/by
> >this information,
> >with all applicable
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> services goto:
> Links
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Good Day Waffgle and Steven:
What size are your db? SQL or Informix?
Were you using a Disk array before, or just drives in the
server?
Version?
len.hartka@...
Of Waffqle
Sent: Tuesday, August 16, 2011 1:54 PM
I'd recommend them wholeheartedly.
client performance in comparison to your server performance. If your
clients are bogged down, improving the server will make little
difference.
> big difference.
> mtonoyan@...
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
~13gb Progress Database
Previously running an 8-disk RAID 10 using direct attached storage.
Currently running the same setup, except 4 SSDs instead of 8 disks.
> server?
> Version?
> len.hartka@...
> Of Waffqle
> difference.
> > big difference.
> > mtonoyan@...
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> viruses.
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Version 9.04
>> server?
>> Version?
>> len.hartka@...
>> Of Waffqle
>> difference.
>> > big difference.
>> > mtonoyan@...
>> *Waffqle Driggers*
>> *:: 904.962.2887*
>> *:: waffqle@...*
>> *:: NO FAXES*
>> against viruses.
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Our database is about 4.5gb Progress. We were using six 15k drives on a Raid 10 before. Now we have two 15K drives on a raid 1 for the operating system and 4 solid state drives on a raid 10 for Vantage and the database. We have about 45 users. The new server is running Windows 2008R2 64bit Enterprise and has Two Intel Xeon X5650 @ 2.67 GHz processors. This gives us a total of 24 cores. 32GB RAM. So it was a big hardware upgrade for us all around.
Â
We also saw a noticeable improvement on our newer clients running Windows 7 64bit and 8GB or more RAM.
Sent: Tuesday, August 16, 2011 2:12 PM
Subject: RE: [Vantage] Epicor running on Solid State hard drives
Â
server?
Version?
len.hartka@...
Of Waffqle
difference.
> big difference.
> mtonoyan@...
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
