Like I said, I've done this multiple times - it's not too bad.
Good luck!
Here are the instructions:
Summary Uninstalling Progress by Removing Registry Entries Manually
Book Vantage General Information
Page 1322MPS
Kbase Id:
18709
Title:
SUMMARY:
Sometimes a 32-bit installation of Progress might be useless or a
removal of the previous installation version has to be done. This
solution details the Windows NT Registry entries that should be
deleted by hand before a new installation can be done.
SOLUTION:
To completely clean the Registry of references to Progress, delete
each and every subtree, its keys, the hive and values described here.
To find the CLSID entries, either use pure luck or search for the
installation directory name FX: (X relates to a SID created at install
time). Progress is installed in C:\DLC\ therefore search for DLC using
F3 in Regedit.
NOTE: Use the Regedit at your own risk because carelessness can render
the operating system useless. Always have a valid and up to date
backup (use REGBACK from the NT Resource kit)
Program Registry entries:
HKEY_CURRENT_USER\Software\PSC
HKEY_USER\{X}\Software\PSC
HKEY_LOCAL_MACHINE\SOFTWARE\PSC
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlset\Services\Proservice(8x/9X)
Version 9.x entries:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlset\Enum\Root\LEGACY_ADMINSERV
ICE9.XHKEY_LOCAL_MACHINE\SYSTEM\CurrentControlset\Services\AdminService9.X
Delete these sub-trees to remove all entries related to the Progress
executables. Most of the time this is enough cleaning and a new
installation can be started:
File extension association:
HKEY_CLASSES_ROOT\.CFG
HKEY_CLASSES_ROOT\.Database
HKEY_CLASSES_ROOT\.I
HKEY_CLASSES_ROOT\.P
HKEY_CLASSES_ROOT\.PF
HKEY_CLASSES_ROOT\.PRL
HKEY_CLASSES_ROOT\.R
HKEY_CLASSES_ROOT\.UDF
HKEY_CLASSES_ROOT\.W
HKEY_CLASSES_ROOT\CLSID\{X}\(Progress Version)
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{X}\(Progress
Version)
HKEY_CLASSES_ROOT\ProgressFileCFG-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileI-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileP-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFilePF-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFilePRL-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileUDF-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileW-(Progress Version)And
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileCFG-
(Progress Version)
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileI-
(Progress Version) HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileP-
(Progress Version) HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFilePF-
(Progress Version) HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFilePRL-
(Progress Version)
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileUDF-
(Progress Version)
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileW-
(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileDB-(Progress Version)
HKEY_CLASSES_ROOT\ProgressFileR-(Progress Version)And
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileDB-
(Progress Version) HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ProgressFileR-
(Progress Version)
Delete these sub-trees plus the CLSID number to remove all entries
related to the File extension association:
Program Entries:
HKEY_LOCAL_USER\Software\PSC HKEY_USER\{X}\Software\PSC
executables:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CurrentVersion\App
Paths
\PROWIN32.EXE
\SHOWCFG.EXE
Just delete this:
Uninstall information:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CurrentVersion\Uninstall
\ProgressSoftware_1
Delete this sub-tree to remove all entries related to the Progress
uninstall (which properly failed since you are doing this):
Performance counters and Eventlog entries:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlset\Services\Properf8
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlset\Services\EventLog
\Applications\ProControl
\Applications\Progress
\Applications\ProService
\Applications\DATABASENAME
V9:
\Applications\AdmService
performance counters.
Reboot and reinstall.
Reference to Written Documentation:
Progress Knowledge Base Solution 19580, "Unable to Access Error Code
44537 When Trying to Uninstall".
Eric L. Tyira
Tamglass Tempering Systems
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Sent: Friday, July 30, 2004 2:49 PM
Subject: [Vantage] Re: Eror code 0x8007007e(5898)
* YEs, Can you please post them that is what i wnat to try completely
wipe it off from regustry and have new installation.
Good luck!
Page 1322MPS
Kbase Id:
18709
Title:
SUMMARY:
SOLUTION:
F3 in Regedit.
Version)
(Progress Version)
(Progress Version)
(Progress Version)
(Progress Version)
(Progress Version)
Program Entries:
executables:
Paths
\PROWIN32.EXE
\SHOWCFG.EXE
Just delete this:
\ProgressSoftware_1
V9:
Eric L. Tyira
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
--- In vantage@yahoogroups.com, "Tyira Eric" <eric.tyira@t...> wrote:
> I've had control frame widget errors on some of our boxes. The
only way I found that fixes this is to manually removed the
installation from the registry and then re-install it.
> I have the instructions from Epicor, so let me know if you want me
to post them.
> Thanks.
> Eric L. Tyira
> P: (856) 786-1200
> F: (856) 786-7606
> eric.tyira@t...
> From: sharma_nalini [mailto:sharma_nalini@y...]
> Sent: Thursday, July 29, 2004 5:53 PM
> I trierd to change few settings and reinstalled vantage but doesn't
> work.
> Actually what i realized,for progress network share installation
it
> does not register shared file in registry just give me finished
> screen and when i start vantage i get these error messages.
> On some workstaions it works ok.
> -- In vantage@yahoogroups.com, "Martin Horton" <martinh@p...> wrote:
> > Usually I see these sorts of error messages (not sure what our
> error numbers
> > are though!) when something is sized incorrectly like when the
> favourites
> > bar is sized to zero to hide it. Another cause is screen
> resolution set too
> > low.
> > Hope this gives you something to go on.
> > Regards
> > Martin Horton
> > Assistant Group IT Manager
> > PRD Holdings Ltd
> > DDI: 01902 639187
> > Sent: 28 July 2004 18:50
> > Subject: [Vantage] Eror code 0x8007007e(5898)
> > Hi All,
> > We are running vantage 6.1 in testing environment.
> > when i try to install client on some of teh machines. every thing
> > goes well but when i start the client it gives me an error message
> > "Error occurred while creating CONTROL-FRAME Explorer. The
specified
> > module cannot be found.Eror code 0x8007007e(5898).
> > Does anyone had thhis problem? please help me.
