Function Library disabled after upgrade 2022.1.18 to 2023.1.10
Upgraded test environment to 2023.1 and I have a function library with 18 functions in there that is disabled and I cannot enable it. Function has been working for a year in production environment. I can delete the function and reference to IssueReturn and save it. Worst case I have to create a new library just for this function, just will be a pain with about 40 widgets and custom code in this function.
The type ‘JobHeadRow’ exists in both ‘Erp.Contracts.BO.IssueReturn, Version=11.2.300.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992’ and 'Erp.Contracts.BO.JobEntry, Version=11.2.300.0,
Edit: I’m stupid hold on.
I thought we were going to have less of these issues not more :rofl:
First, try referencing the full names of the type, and see if that fixes it.
Otherwise you may have to make a workaround.
More often than not it will come to this. This is a major pain point no doubt.
I don’t think you can reference the full type in Widgets and Variables. I tried using “Other” and selecting the service to see if the full name would populate. Dang it.
Ahh widgets, the bane of my existence.
I would break my workflow into 2 (or an appropriate number) of functions then.
It’s time to start reporting these as bugs, if y’all aren’t already.
The same types should not be defined in more than one assembly.
One place, one reference.
This was reported as a bug back in Epicor 9. It never went anywhere it technically isn’t a bug is just a poor design choice. You can have the same type defined in different DLL’s as long as you reference them via an Alias
Its a dumb choice.. but its a choice.
I’m aware, but I’m gonna be an a** until they submit to my will.
You mean widgets broke on upgrade?!
oh-my-shocked1
You can fix this with custom code
giphy1
ah, this again…
