My Crystal Reports problems seem to continue.... I recently migrated back
from 8.5 to 8.0. And I ran into problems with the left outer joints between
Merant and Crystal. I found and applied the following fix (revert to older
.DLL and add registry hack):
http://support.crystaldecisions.com/library/kbase/articles/c2009129.asp
http://knowledgebase.merant.com/cgi-bin/webcgi.exe/,/?Session=28410,U=1,ST=5
6,N=0012,K=13461,SXI=5,Case=obj(22946),Note=22946,VARSET=CASEID:22946
Then there is the ODBC SQL-92 log on box, for which I am followed Epicor's
suggestion (in KB 1732mps) of creating a file DSN with a built in password:
http://eportal.epicor.com/eportal/ansbook/vantage/public/1/17/173/1732mps.ht
m
I am able to test my connection using the option in Control Panel's
Datasources ODBC area.
However, when I create a little test report, I am getting the following
error:
Seagate Crystal Reports: Database Error
ODBC error: [MERANT][ODBC PROGRESS driver][PROGRESS]Unable to allocate disk
block for temp table use [MM - No data block] (7631)
Has anyone come across this before?
TIA,
Paul Siebers
m
error:
TIA,
Paul Siebers
