I just upgraded last Tuesday night from 5.10 to 5.20 and had to do the same
thing. What I got told was after I did the procopy I needed to start the
9.1D Service and run the schema changes I was talked thru this with someone
from Vantage. After the schema changes ran I installed the client on the
server and made the appropiate drive mapping then did the exact thing on my
system and when I opened Vantage for the first time it went thru a database
conversion.
Tracy
Sent: Tuesday, December 09, 2003 9:26 AM
Subject: [Vantage] HELP - MOVED DATABASE NOW RECEIVING ERROR
Good Morning group -
I need the expertise of the group again -
I received instructions from Epicor on how to move the database to a
another drive.
I followed their instructions - now I am receiving the following error.
Start Up on Database localhost 20931;epic52 failed; File not Found
[junmsg023]
Here is what I did - maybe they missed something
They had me procopy the database and then go under epic52 database in
the progress explorer and right click properties to change the path for
the database files. Which I did. When when I go to start the database
this is the error I receive
BTW - Version 5.2
Best Regards,
Dina Hieber
Vamco International, Inc.
(412) 963-7100 Phone
(412) 963-9511 Fax
conversion.
Tracy
another drive.
[junmsg023]
BTW - Version 5.2
Best Regards,
Dina Hieber
(412) 963-9511 Fax
