How do I Stop Phantom Session?
Mario - I started this thread and ended up solving it with PROMON.
Thanks for all the advise. I saw in Vantage HELP the utility you
suggested and tried it on the server, but the "disconnect" option was
still greyed out. PROMON worked fine and now I know!
Bob
--- In vantage@y..., Mario Aguirre <maguirre@l...> wrote:
> You could also install vantage client in your server, run a session
using
> your mapped drive, go to system management/utilities and open
connected
> users. The disconnect option will not be grey-out since you are
running
> vantage from the server (note this is recommended by Epicor, yet I
continue
> using PROMON).
> Mario Aguirre
> Information Systems Manager
> Lakin General
> 2865 N. Paulina
> Chicago, IL 60657
> Ph: 773-871-9631
> Fx: 773-871-1265
> -----Original Message-----
> From: candymachinemaker [mailto:bob@s...]
> Sent: Friday, May 10, 2002 10:27 AM
> To: vantage@y...
> Subject: [Vantage] How do I Stop Phantom Session?
> We are a new user to Vantage still in impementation stage. I had a
> PC crash while logged into Vantage. Process must still be running
in
> Vantage because record locked out that was being edited at time of
PC
> crash. Error says "bob" is logged in when he is not.
> What tool do I use to cancel "bob" session? I am running Progress
> 9.1c and Vantage 5.10.116.
> Thanks!
> bob
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
PC crash while logged into Vantage. Process must still be running in
Vantage because record locked out that was being edited at time of PC
Thanks!
bob
You need to get into promon (see your install instructions), go to # 8 stop
the database (it only sounds scary) and kill the offending session.
Alternatively rebooting the server cleans things like this up as well. Feel
free to call me with more specific questions.
Oleg Tumarkin
Intelligent Systems Integration
(330) 335-5291
olegt@...
"Making Intelligent Use of Technology"
You either need to restart the server or disconnect the user from Promon.
Mike Tonoyan / All American Products Co.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, May 10, 2002 8:26 AM
> Thanks!
> bob
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You could also install vantage client in your server, run a session using
your mapped drive, go to system management/utilities and open connected
users. The disconnect option will not be grey-out since you are running
vantage from the server (note this is recommended by Epicor, yet I continue
using PROMON).
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Thanks!
bob
I just tried to end my sesion on our server (we have a client installed) and
it didn't work. the "disconnect" option is not greyed, when you click it a
dos app opens up and then disappears. my session is still running....
any suggestions?
Sent: Friday, May 10, 2002 12:15 PM
Subject: RE: [Vantage] How do I Stop Phantom Session?
using PROMON).
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Thanks!
bob
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=17050071
83:HM/A=1036975/R=0/*http://www.ediets.com/start.cfm?code=3225> Click Here!
<http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egroupmai
l/S=1705007183:HM/A=1036975/rand=407762264>
Kelly,
On the Vantage server pull up a DOS prompt, cd into your PROGRESS\bin
directory and issue the following command:
_mprshut -0 C:\epic51\vantage\db\vantage.db
Where C:\epic51\vantage\db\vantage.db is the path to your Vantage database
file. It should pull up a program in the console where you can press 8,
take note of the number listed in the 'usr' column of the user you want to
dump, press 1 to disconnect the user, and enter the user number you want to
zap.
Let us know how you make out,
AE
Sent: Friday, May 10, 2002 2:03 PM
To: 'vantage@yahoogroups.com'
any suggestions?
using PROMON).
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Thanks!
bob
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
ADVERTISEMENT
83:HM/A=1036975/R=0/* http://www.ediets.com/start.cfm?code=3225
<http://www.ediets.com/start.cfm?code=3225> > Click Here!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
83:HM/A=1046314/R=1/*http://www.ediets.com/start.cfm?code=3225>
83:HM/A=1046314/R=2/*http://www.ediets.com/start.cfm?code=3225>
Height: 4 5 6 7 ft 0 1 2 3 4 5 6 7 8 9 10 11 in
Weight:
Sex: F M
l/S=1705007183:HM/A=1046314/rand=791302407>
Without trying it, I assume that command is calling promon. That is what I
have been using to kill phantom sessions. I was hoping that doing it within
Vantage would be a little less painful, but I could not get it to work.
Kelly
Sent: Friday, May 10, 2002 1:35 PM
Kelly,
zap.
AE
any suggestions?
using PROMON).
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Thanks!
bob
<http://groups.yahoo.com/group/vantage/files/.> > >
<http://groups.yahoo.com/group/vantage/messages> > >
<http://groups.yahoo.com/group/vantage/links> > >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > >
ADVERTISEMENT
< http://www.ediets.com/start.cfm?code=3225
<http://www.ediets.com/start.cfm?code=3225> > > Click Here!
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > .
ADVERTISEMENT
83:HM/A=1046314/R=1/* http://www.ediets.com/start.cfm?code=3225
83:HM/A=1046314/R=2/* http://www.ediets.com/start.cfm?code=3225
Weight:
Sex: F M
ADVERTISEMENT
l/S=1705007183:HM/A=1036975/rand=603903836>
