That was the ticket, I was using a UNC path instead of the drive letter
path.
Thanks for all your help,
Jeff
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
Sent: Tuesday, April 26, 2005 4:53 PM
Subject: Re: [Vantage] Hung or idle Vantage sessions
Here are instructions directly from support:
PROMON NEEDS TO BE SETUP ON THE SERVER
Progress Monitor (PROMON) displays performance and usage information about
database status and activity. This utility also allows you to disconnect
individual users.
PROMON can be invoked at the DOS prompt or invoked through a Windows icon.
To run Promon from a DOS prompt:
1. At the server, open a DOS session.
2. Change directory to: c:\epicor\prgs91D\bin (Where 'C' is the physical
drive letter where Progress and Vista are installed)
3. Type: promon c:\epicor\mfgsys60\db\mfgsys.db and press enter
You will see the Promon menu.
To Run From Windows Icon (Version 6.0)
1. Creating a PROMON Icon
2. Right Mouse click on the server desktop and create a new shortcut.
3. Click the Browse button and map to c:\epicor\prgs91d\bin\_mprshut.exe
4. Click Next
5. Rename the shortcut to Promon
6. Click Finish
7. Right mouse click on the new icon and choose properties.
8. In the Target line click the cursor after the text
"C:\epicor\prgs91D\bin\_mprshut.exe" and type:
-0 C:\epicor\mfgsys60\db\mfgsys
9. In the Startinline change the path from c:\epicor\prgrs91d\bin and type:
C:\epicor\prowk91D
10. Save the changes.
(Again, 'C' is whatever physical drive you have installed progress and
Vista to)
USING the PROMON MENU
PROGRESS MONITOR
Database: c:\epicor\mfgsys60\db\mfgsys.db
MENU OPTIONS:
1. User Control
2. Locking and Waiting Statistics
3. Block Access
4. Record Locking Table
5. Activity
6. Shared Resources
7. Database Status
8. Shut Down Database
T. Transactions Control
L. Resolve Limbo Transactions
C. Coordinate Information
M. Modify Defaults
Q. Quit
Enter Your Selection:__
TO DISCONNECT A USER
Choose Menu Option 8, 'Shutdown Database'. This will not actually shut down
your database but will give you access to another screen.
In this second screen choose option 1 'Disconnect a user'. Find the number
that corresponds to the user you wish to disconnect.
path.
Jeff
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
individual users.
4. Click Next
6. Click Finish
C:\epicor\prowk91D
Vista to)
PROGRESS MONITOR
MENU OPTIONS:
1. User Control
3. Block Access
5. Activity
6. Shared Resources
7. Database Status
M. Modify Defaults
Q. Quit
----- Original Message -----
Sent: Tuesday, April 26, 2005 10:43 AM
Subject: RE: [Vantage] Hung or idle Vantage sessions
Thanks for the responses.
Now, what is the syntax for my database name in Promon?
I've tried UNC and IP:port with no luck.
Are there instructions for this utility somewhere?
I'm stuck at the front door.
Please help.
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Thursday, April 21, 2005 10:08 AM
There are 2 different utilities we use depending on the type of hung
session. There's PROMON and also the SYSUSR52.R utility (this is the name
for 5.2 which we are still on). For the sysusr program, you have to call
support to get it and it comes with instructions. For promon, you need to
first set this up on your server, then option 8 to kill a session. I
believe the instructions for setting up promon are part of the Vantage
install guides - if not I know I've found them in the past by searching
the
vantage answerbook. You can also end user sessions directly from Vantage
on
the server only through "System Management" -> "Utilities" -> "Connected
User" -> "Disconnect"...
have
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
<http://groups.yahoo.com/group/vantage/> >
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
_____
Yahoo! Groups Links
