Matt,
After a while using promon, there is the possibility that the user name will
disappear from the screen. The connection is listed, yet no user is
associated with it. Epicor has this listed as an issue, but I am not sure
how it is categorized.
If your user names disappeared, you could:
1. Use the System Configuration/Utilities/Connected Users to view the
connection number and disconnect the user using promon.
2. Rename and modify your .vtg file to point your physical drive, run a
client session of Vantage using the modified .vtg file from the server and
disconnect the user using the utility in Vantage (suggested by Epicor).
I updated over the holidays to 5.1 and I have not tried the second one yet.
Has anybody experienced this problem using promon and 5.1?
Mario Aguirre
Lakin General
Sent: Wednesday, January 02, 2002 2:36 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] 5.1 Promon
Thanks Lydia....I lasted three hours before I needed to kill someone.
Sent: Wednesday, January 02, 2002 2:23 PM
Yes, Yes and yes! I got these instructions from tech support this
morning-had 5.1 running for one whole hour when I needed to kill a user in
ProMon. This is long, but worth having.
Lydia
Mario Aguirre
Lakin General
Lydia
