James,
I had a similar problem with my HP LH3 server. We replaced so much in that
server it was like getting a new. I updated the Bios and Raid firmware.
Support finally upgraded to call to the next level
The engineer had me straightened out in no time.
I had to pull the scsi cable from the drive cage - boot the computer -
delete the drive config. reboot redo config - reboot - then run an
consistency check. DO NOT DO THIS WITHOUT HP THOUGHT.
But it did fix my problem for good.
Hope this helps.
Nancy
I have a lengtly problem that I wondered if Vantage or Progress could
be causing
To make a long story short
We have a HP LH3000 Net Server
I am running Vantage 5.118 and Progress
I have two 9 gb SCSI Hard Drives with a hardware mirror
I have had problems for two months with the first drive
It keeps failing
I have done EVERYTHING I Can think of!
HP Has replaced EVERYTHING IN the machine
Both Hard Drives
SCSI Back Plane
SCSI Cables
And the motherboard
Guess what
Still having problems with the drives failing
I have reformatted the drives and done a fresh install on Vantage and
progress TWICE
HP Has a 29 day turn around on getting me a new server
While I am waiting and "babying this thing"
I was asked by Micron (Thats who they got the server from)
COuld it be something your software is doing?
I am going to contact Epicor about this but I have been all the way
in the hardware configuration and it says that the drives will not
spin up or initilize or or or
Anyone else had anything similiar?
James Piper
Meco Inc
admin@...
Hope this helps.
Nancy
be causing
It keeps failing
Both Hard Drives
SCSI Back Plane
SCSI Cables
And the motherboard
Guess what
progress TWICE
James Piper
Meco Inc
admin@...
