HP Server Progblems, Can Progress or Vantage be cau sing this
Did you have an ACTUAL hard drive failure or did you just get a message like
this one: "FT Orphan, a disk that is part of your Fault Tolerant system can
no longer be accessed"?
Also, what OS, version & patch are you on?
Lydia
lcoffman@...
Canyon Engineering Products
What version OS are you on, patch, security fix, etc... and when was the
last time you modified the OS?
Sent: Friday, May 10, 2002 9:22 AM
Subject: [Vantage] HP Server Progblems, Can Progress or Vantage be
causing this
I have a lengtly problem that I wondered if Vantage or Progress could
be causing
To make a long story short
We have a HP LH3000 Net Server
I am running Vantage 5.118 and Progress
I have two 9 gb SCSI Hard Drives with a hardware mirror
I have had problems for two months with the first drive
It keeps failing
I have done EVERYTHING I Can think of!
HP Has replaced EVERYTHING IN the machine
Both Hard Drives
SCSI Back Plane
SCSI Cables
And the motherboard
Guess what
Still having problems with the drives failing
I have reformatted the drives and done a fresh install on Vantage and
progress TWICE
HP Has a 29 day turn around on getting me a new server
While I am waiting and "babying this thing"
I was asked by Micron (Thats who they got the server from)
COuld it be something your software is doing?
I am going to contact Epicor about this but I have been all the way
in the hardware configuration and it says that the drives will not
spin up or initilize or or or
Anyone else had anything similiar?
James Piper
Meco Inc
admin@...
