I'd second that the partition layout doesn't make much sense.
But like they said, you should be able to just move everything over as long
as you have the same drive letter in the end.
Personally, if it was my box, I would just load the new drives, scrap all
the partitions, make a raid 10 out of all 4 drives and rebuild the server.
It's a bit more work, but the overall time to get the server back online
should be about the same and you'd have a more 'standard' configuration,
better fault tolerance and much better IO performance.
On Mon, Apr 26, 2010 at 1:12 PM, Ned <TechnoBabbly@...> wrote:
> Just make sure everything is shutdown before you make the copy, but there
> shouldn't be any reason why this won't work.
> However, I am not sure who did your initial installation, but installing on
> that type of drive layout shouldn't have been done in the first place.
> From: "ap4584480" <ANDREWN@...<ANDREWN%40ABILITYPLASTICS.COM>
> To: <vantage@yahoogroups.com <vantage%40yahoogroups.com>>
> Sent: Monday, April 26, 2010 12:18 PM
> Subject: [Vantage] I need to increase server 2003 drive size
> > Hi everyone, I have a mirrored container divided into a C & D partition
> > with vantage installed on D. I'm running out of space on the C
> > (operating system) part of the drive.I want to install a new mirrored
> > container to move D (vantage partation)to.Is there anything special I
> need
> > to do to be certain vantage will operate on the new mirrored
> container.Can
> > I just shut down the data base and copy everything in D to the new
> > container,deleat the old D and rename the new drives D. Any tips, or
> > potentinal probems I could avoid Would be greatly appricated.Thanks
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
