Hi Everyone, I hope I can add some clarity in regards to the IEX, this is going to be a long post :).
Starting version 10.1.600, Positive Pay and MICR Checks were included in base product. Specifically for this two extensions you need a module license to be able to access it.
The rest of the IEX (AP & AR ACH, Payroll ACH) are supported up to version 10.2.100, and are part of base product starting again in 10.2.300.
If anyone need the installers for version 10.2.200, since they are not supported as extensions in that version, you will need to contact CSG, and they can provide them.
For all the applications, as soon as they became part of base product, the framework is no longer needed.
Now, I’ll try to answer the specific questions:
1.- Does Epicor have a Script to remove IEX tables?
-I dont know of an “Oficial” script to drop those tables, but our support team should be able to provide one if a ticket is created asking for it. What I can confirm is that those table are not used if the extension is part of base product.
2.- What happened to ACH in 10.2?
-Is part of base product starting in 10.2.300, this one is free (no license required) and Epicor provides a template to use it that follows the standard NACHA specifications.
3.- Positive Pay programs are shipped with 10.2 but for some reason require a license to run.
-Correct, Pay does require module license to be used, it includes 5 different bank formats that, same as the rest of the templates provided, work as examples that can be used/modified to your specific needs.
4.- We’ve upgraded to 10.2 and ACH is not working. Message: File C:\inetpub\wwwroot\ERP102\Server\Erp\EI\IEX_Payment_APACH\IEX_Payment_APACH.cs not found to compile and run.
-This is because the doesn’t exist in the folder, the reason is because with upgrades, tipically only the core files/assemblies are deployed in the new version, so most of the custom solutions (in this case the IEX) needs to be reinstalled.
-You will need to run both installers again (Framework + ACH) if your version is 10.2.100, if you moved to 10.2.200, you will need to ask CSG for the installers to that version, and if you are in 10.2.300 you dont need to do any of this just look for the new template (Payment_US_ACH_Domestic) .
5.- …I dont see a 10.2.300, but perhaps the 10.2.200 will work.
-This is true for all installers, they need to be compiled in the right version, so an installer from 10.2.200 wont work in 10.2.300.
-And you dont need to do anything in 10.2.300, just look for the new format name.
Let me know if I missed any question or if you will like me to elaborate on any of the above…
